The RAM 1500 with the 4.7V8 also used the 65RFE six speed automatic tranny. Assuming the bell housing mount to the 1500 4.7 is the same as bell housing mount for the 4.7 in a DAK, can a 65RFE tranny be installed and work properly in a Gen III Dakota? Would the TCM for the tranny from the original chassis also work if installed into a Dakota. Or does the engine PCM also talk to the 65RFE TCM in such a way that the 65RFE only works if it is also identified to the original engine/PCM that the tranny was mated to in the factory?
