I have a 2001 Dakota and can't for the world of me figure out how to put the auto trans into neutral for flat towing. Will someone please show me how? :huh:
you cannot do that on that transfer case switch.I'm assuming you have the electronic tcase shifter? Put the truck in neutral and switch it all the way left to N you may have to roll the truck a little to get it to shift properly
I have the same, 2wd, 4 hi, and 4 low. When the red light is flashing, let the truck roll a little bit, and it will go into N. You can put it in drive and test it out if you need to.The knob on the electric switch will not go to the bottom left where the N with the red light is.
Does the vehicle have to have power to soft top neutralI'm assuming you have the electronic tcase shifter? Put the truck in neutral and switch it all the way left to N you may have to roll the truck a little to get it to shift properly
