1 - 20 of 29 Posts
guys this is going to be a ongoing review to help and guide other members with there future HO projects. If you have specific questions or advice please feel free to comment below. So let's get into it.
The 4.7 HO and standard 4.7 are physically almost identical externally. The HO block has 2 spots under the intake manifold for knock sensors. The High output heads are clearly stamped with a HO on both the passenger and driver side heads. The HO might not be visible if the engine has all of the accessorys on it since the AC and alternator tend to cover HO up.
On the inside things get interesting.
CAMS
Standard 4.7
Duration 244/254 deg
Lift 0.443/0.429"
Lobe separation angle 115.5 deg
4.7 HO
Duration 236/250 deg
Lift 0.472/0.429"
Lobe separation angle 112.5 deg
Notice the lower LSA on the HO cam. I would speculate this is why the HO cams make better mid range power over the standard 4.7 cams despite having slightly less duration.
Pistons
The HO piston has a nearly flat top on it that brings compression to 9.7 to 1 compared to 9.3 to 1 of the standard 4.7. its also worth noting that the HO uses a stronger floating wrist pin design vs the pressed in pin used on the standard motors.
CRANK
The HO has a stronger forged crankshaft vs the standard 4.7s cast crank. The bearing material is also different to accommodate the stronger material. Interesting enough the HOs harmonic dampener is also specific to the HO to minimize vibration and reduce crank wear.
Injectors
MYTH!!!!! The 4.7 and 4.7HO use the same injector!!! I have looked at a few web sites that say the HO 4.7 uses 25lb injectors compared to the standard 4.7s 22lb injectors. In my experience this is false since both injectors use the exact same part number. I suspect the diffrence in flow is from the PCM commanding more fuel pressure.
More coming soon. And pictures!
Ok now for the swap portion of this Thread.
Swapping the 4.7 and 4.7HO is very simple but a few miner issues may come up.
OIL PAN. The oil pan from the Grand Cherokee Overland is slightly different from the Dakota and Durango oil pan. The Cherokee pan will hit the front differential on the dodge and will need to be swapped out for the Dakota pan. I highly recommend replacing the oil pan gasket when doing this. If you install your oil pan correctly it should be leak free for many years and is cheap insurance.
MOTOR MOUNTS: You will reuse the Dakota/Durango motor mounts. The Cherokee mounts are slightly different and mount to the block differently. Don't worry the bolt holes for the Dakota/Durango mounts are there and you simply install the dodge mounts in the same locations as you normally would.
INTAKE MANIFOLD: Depending on what manifold you use you may need to make miner adjustments. In my case I used the 04 HO manifold and the hose running to the oil fill tube for the crank case depression system had to be slightly modified. In addition my throttle cable needed a small rubber shim behind the pedal to take up some slack in the cable. This was not a huge issue and could be from normal wear and tear on the cable. I took the time to replace the intake manifold O ring gaskets since I had every thing apart however they are reusable and its personal preference.
IAT (intake air temp sensor): Different 4.7 intake manifolds use different locations for this sensor. In my experience the factory sensor wiring was long enough to reach the sensor location on the HO manifold. I elected to extend and relocate my IAT sensor to the intake tube a few inches in front of the throttle body. This lowered by intake air temp reading by about 15F.
IACV: I noticed a slight difference in the dodge and Jeep IACVs. Both can be used and seem to work with out issue. What I did notice is the truck seems to idle a little better with the jeep control valve. I do recommend cleaning both the head of the IACV and TB because they tend to build up carbon and can cause miner issues.
Exhaust Manifolds: It appears that the exhaust manifolds on the jeep and dodges are different and will probably need to be swapped out for the vehicle specific manifold. I installed a set of JBA headers that fit perfectly and bolted to the stock exhaust Y pipe. A year latter they are holding up well and are leak free.
OIL Pressure Sensor: The Dodge and jeep oil pressure sensors are different one being a single wire sensor and the other being a two wire sensor with both using a two pin plug. I found this out when I plugged the factory plug into the Cherokee oil pressure sensor and was terrified when the oil pressure gauge was reading 0 while cranking. Fortunately I checked the sensors are sure enough one has a two wire pin in the plug and the other is a single. Simply unscrew the oil pressure sensor and re install the stock one off your old 4.7. Problem solved.
PCM and tuning: As long as you have paired your toner wheel and PCM correctly (see below) your stock PCM will run the HO engine and you will notice a power gain however you will need tuning to capitalize on the new engine. DO NOT RUN THE JEEP PCM!!! I have tried and so far I have been unsuccessful. I am running hemifever tuning and it definitely woke up the truck and helped dial her in.
KNOCK SENSORs: They are simply not used. I have mine installed but the plugs don't have any where to plug into on the stock dodge wiring harness.
JTEC and NGC: It is important to know if your truck has a 3 plug JTEC PCM or a 4 plug NGC PCM. This is one of the most confusing parts of the swap. This is not as complicated as many people make it seem. Tone rings are interchangeable as long as you swap the hole timing set to do it. I highly recommend replacing your timing set any way while your motor is out. Its a small investment compared to dealing with it latter if your used one should fail.
***The 3 plug JTEC PCM uses a 16 tooth tone ring and has a separate 1 plug TCM located in front of the air filter housing next to the radiator.
****The 4 plug NGC PCM uses a 32 tooth tone ring and does NOT have a separate TCM.
NOW........................... For my impression.
THIS IS NOT A HEMI SWAP. It is definitely a noticeable upgrade with more useable power across the hole RPM range. This should be considered a subtle upgrade and is probably a excellent option for guys looking to go forced induction or nitrous induction who don't have the skills or budget to build a all out race motor.
For me the justification was simple. My truck had 140K on the clock and had been owned by a younger guy who beat the heck out of her prior to me owning it. I was going to overhaul the stock 4.7 however found a 4.7 HO from a wrecked overland with 92,000 miles on it locally for $600. The motor was in excellent condition but I elected to overhaul it while it was out including new timing set, gaskets, oil pump, water pump, bearings, valve seats, and so on. I feel very confident I could have dropped the motor directly into the truck and it would have been fine but I am hoping to get another 100K out of my truck so it really was a no brainer.
At the time I swapped the motor I was running 265/75 16 Duratracs and had just finished a 545RFE conversion. The truck is running 3.92 gears and is a 4 door tiping the scales at just under 5000lbs. I towed regularly with the truck and noticed that the extra high overdrive would bog down and hills at 55-65 mph do to the lower RPM's. This would not be a big deal except the truck would kick down from 5th to 3rd gear causing the motor to rev higher then I liked. Unloaded the truck didn't seem to have this issue.
Nice write up man. I plan on doing the HO swap in 00 Dakota quad cab as well. All that info you posted definitely will help somebody that doesn't know what's involved. I just wanted to know what you had to do for your 545rfe swap. I've definitely done everything I can to try and squeeze out every MPG possible of my Dak. That 5th gear would be nice! Also just a recommendation, if you're towing, try to keep your OD off unless you're going above 65 and are on completely flat roads. Being at such a low RPM in OD when pulling a trailer puts quite a bit of stress on the trans. Just figured I'd throw in my 2 cents!
Discussion Starter · #4 ·
For the 545 conversion all you need is a TCM from a Grand Cherokee that comes with the 545RFE. This will of course only work if you have a JTEC 3 plug ECU and the 1 plug TCM. I am running a BD line booster for a 65RFE cummins transmission and a transgo shift kit as well.
The extra gear definitely made the truck more enjoyable to drive on the highway. As far as towing goes we have 70 mph speed limits so with smaller loads 5th gear still keeps it in the power-band as long as your over 60 mph My truck is 3.92 gear ratio so 3.55s may be a little different story.
Thanks for the reply. I was actually looking up the 45rfe to 545rfe conversion and it's crazy the only thing needed is different programming. Chrysler should have thought of that when the 45rfe was launched! My dak is a 2000 so it has the 3 plug jtec pcm. I ended up getting a used tcm from an 01 cherokee for $25 on ebay, which was a steal. I too have the 3.92's, so I'll definitely be looking forward to the decrease in rpm's on the highway. Anything to help fuel mileage will be huge. Our trucks are such pigs on gas. Manual locking hubs in the front would be nice too, but I've yet to find a company that sells a kit!
great info. i am about to start a 4.7 to 4.7h/o swap myself. got great deal on low milage truck with "bad motor". turns out it was a head problem, I plan on driving a while so upgrading seems to make sense right now. i have a 05 dakota, if you have came across anything i should watch out for please up date.
hoping to order motor in day or so, am i missing any thing not in cbr600's post
update: found h/o motor with 32 tooth tone wheels remanufactured. trying to order a.s.a.p, has no one tried this swap, or have any info? i have the ngc pcm, motor is out, and ready to order new/reman. motor.
I have a 03 durango that i bought for 600. the motor is bad. I am disabled and am looking to put a used motor in it, but am having trouble finding a motor that will slide right in it on my limited budget. it is the 32 tooth tone wheel, and has the ngc controller. is it possiable to put an older 4.7 in it if i switch out the wiring harness and ecu? i found a motor for 300, but its the older 4.7. can i change the pcm, tcm and the harnesses. will it work?
I would check on car-part.com for the 4.7's with the 32 tooth tone wheel in your area. They look up all those engines for you and sort them by closest to your zip code. I would try that before you start trying to switch out harnesses and what not. A lot of the older JTEC 16 tooth 4.7's use a CCD bus and not PCI like yours. So you would have to change your gauge cluster, as well as airbag and abs modules too in order to get everything back to 100%. Good luck in your search!
ok, I really dont care about the airbag. i really dont like airbags personally anyway. I really think they do more harm than good. I just need to know if it would work or not. Like I said I am disabled and am looking for the most cost efficient for me to be able to have a daily driving vehicle thats it.
I understand. Finding the correct motor would be the most cost effective then. You could also find an older 4.7 and just swap your 32 tooth tone wheels for the 16 tooth wheels. That would involve tearing the entire engine apart, however. As for the ABS module, that can be changed relatively easy. You just need to change the top module part and not the entire pump assembly. The airbag module is easy to replace as well. By the way, since your engine is a 32 tooth, the PCM and TCM are 1 single unit with 4 connectors vs. being seperate on the JTEC models and having only 3 plugs. So that would be another issue you'd run into. Like I said though, finding the correct 32 tooth engine would be the best thing to do. If you want to tell me your zip code, I can do the engine search for you.
well, i found the older 4.7 for 300. i did the search and cant find one for less than 1200. i can get the older 4.7 and the jtec and tcm and all the wiring harnesses for about 500. my cousin is a mechanic and will do the swap for me for 300, so i can get everything for about 800. which is 400 cheaper than i can get just the 32 tooth motor for. which is the most cosr effective for me. like i said i am diabled and live on 700 a month
You'll end up spending more trying to put in a different motor. Your curret instrument cluster, air bag, and abs module won't work, as I stated before. Plus you'd need to program your vin # and mileage to the old 4.7 PCM and not to mention if your truck has a SKIM (Sentry Key Immobilizer Module) and the other donor 4.7 didn't have one or vice versa. You're better off just taking the $300 4.7 and swapping over your tone wheels then just dropping it in without changing anything else. Going the other route would be saving a nickel just to spend a dime.
· Premium Member
Why would you need to change complete timing setup? crank and cam sensors where the only thing I thought
You are correct, the only thing that needs to be changed would be the both CRANK & CAM tone rings.
A complete timing sets comes with the cam tone ring.
I do however HIGHLY recommend a new timing set for any engine swap. Its just a small short term investment for a much longer term investment.
SPEED SAFE, AIR RAM
1 - 20 of 29 Posts
