1 - 7 of 7 Posts
I am looking at an 02 Durango with a bad 4.7. I have an 03 Durango with 5.7 with only 155k. Everything on the 02 is better except engine. How difficult is swapping? I presume transmission and driveline swap too? 5.7 uses bigger transmission correct? Thanks
4.7 to 5.7, from what I read is easier due to the transmission being the same.
4.7 to 5.9, is more work as the transmissions are different.
You would have to swap engine harness, transmission harness, engine, engine mounts, transmission, transmission mounts, driveshaft, pcm.
So how did it go with the swap.did u have any trouble
8 months later I'm still trying to get this 5.9l running .I have 5 dam pcm in my garage an one broken.an the one that broke was the one that work..lolthe engine came out of a durango.well I have two pcms an all it does is start real fast an turn off.....help
1 - 7 of 7 Posts
