1 - 19 of 19 Posts
We have a '01 Durango with a 4.7
Changing the oil filter is such a PITA. I can't find a way to change it without pouring a bunch of oil into the plastic undertray, which then leaks out between it and the crossmember.
Anyone addressed this yet, or do I need to find the answer for the board?
If I can solve this, I'm going to start running the larger oil filter (Motorcraft FL-1A over the FL-300)
cut the end off a 2 liter pop bottle. and loosen your filter. then place the bottle over the filter and squeeze and turn. the bottle will hold all the oil that comes out and no more mess on your frame. saw this over on another dakota board a while back. :biggthump
A remote filter is a fitting that mounts in place of your oil filter. It has two long high pressure hoses that run to another mount that the oil filter mounts to. You can mount it anywhere the hoses will reach. It's a good idea.
I just use a heavy duty plastic bag, and after the filter is loose I out the bag around it and take it off. No mess.
Many people use the plastic bag that their newspaper comes in. Slide it on like a filter condom and unscrew. Don't get too many of those bags here in sunny AZ, but had tons back in IL.
That is a magnificant idea.... I'll be doing that from now on.... thanks!
Paul
Mike
I usually dont get a mess when i take mine off....but i dont have the plastic undernegth anyways...just wipe alittle bit off the crross memeber and i'm finished
Mine is the same way. Couple of drops on the cross member... wipe that off and I'm good to go.
I've used the plastic bags and the coffee container and still have a mess every time.. My problem is that the filter doesnt fit through all the suspension components, radiator shroud, alternator parts, etc. It's like figuring out a puzzle trying to get the filter out after I get it off. 2004 Jeep Grand Cherokee 4.7.
1 - 19 of 19 Posts
