It's not my fault!
I am in the process of doing the swap right now in my 92. You do need some extra things, depending on the engine you pick up.
Harmonic balancer for a 360 - 318 one will not work
360 flexplate - Make sure it matches your TQ. They changed in 96 or so.
Injectors - always good to upgrade to 21 or 24 lb units on a 360. Connectors changed in 2000, so keep that in mind.
360 PCM - 318 will run it, but not well.
All accessories will bolt up, so no problem there. I'll let you know if it was worth it when I get it done, hopefull next month. Only about $120 away from finishing up.
