So the other day, i was just crusing along and all of a sudden noticed a squeak/knock nois coming from the motor.
Pulled over and thought it was the belt, sprayed some dressing on it and did nothing. Got it home and really started looking. It is coming from the very front cylinder on the drivers side. If you grab hold of the sparkplug connector, you can feel a small vibration everytime the cylinder fires. it is not noticible in other cylinders, just this one.
It wont make the noise (or sometimes hardly) at idle or no throttle cruise. However, when you are under load, it is very noticable. The sound is rev matched with the motor.
Could this possibly be a broken valve spring?
There is no oil coming from the exhaust and does not smoke or perform any different then before.
I would like to have a list of possibilites before i tear the valve cover and heads off.
Thanks guys!
Thanks guys!
