Dualing Durangos 00 & 07
Hey Folks,
I have a 2007 Durango that has no available Fan Speeds. This occurred without any prior warning. Started vehicle (of course was 95 out) and went to turn on AC and No Fan. There is some air being moved out of the vents, I feel the cold when AC is on, but I have no fan speeds when I turn the knob to any speed. My concern is that I have read all about the resistor, which is a common issue, but it seems that the resistor failing leaves the fan on permanent high. That is not the case here.
So has anyone had this No Fan at all dilemma? Could it still be a resistor? Is the control panel more likely? (I do NOT have the digital controls BTW)
As always, Thank You for your time. :smile:
quite possibly Bad fan motor .
It's behind the glove box on the right side.
It has orange and black wires to it in a 2 blade connector, toward the top of the AC/heat box.
You can disconnect the connector and apply +12 volts to the orange wire and ground the black wire to see if the fan spins.
My guess it it won't spin.
I had the same happen to our '00 Durango a while back.
New fan motor resolved the issue.
