I have a 2007 Dakota. It has 204,000 miles. Occasionally when trying to start after I get to destination my truck will crank but not run when starting so I can leave. After about 10 seconds the starter stops cranking by itself. Several more tries and it still won't. Sit 5-10 minutes and sometimes it will start, sometimes it won't. It is not throwing any codes at all. I have replaced starter, and key ignition switch with new key and the ignition switch on other side of steering column. When I crank motor the tach is registering a signal. I have heard bad computer, fuel pump. Don't want to throw parts at it! Has anybody seen this issue or have any paths or tips I can try??
I really appreciate any help I could get!
Thanks
A few thoughts of things to check:
Have you checked the fuel pressure?
Have you checked an injector circuit?
You might check or swap the ASD relay.
Have you checked the spark plugs for appearance and correct gap?
