Sounds like you are headed in the right direction. I used either Ram or Durango manifolds in my swap, I had both and can’t remember which one fit best. I had to slightly notch the frame to clear the oil filter and I notched a Ram oil pan to clear the cross member. I also had to grind a little off the passenger control arm to clear the exhaust manifold on that side. The only other clearance issue is the spark plugs under the booster are a tight squeeze, but I was able to grind down a cheap spark plug socket and it fits without removing the booster
. I hope this helps.
