1 - 20 of 25 Posts
Well, First of all, great forum! I have got more out of these threads in the last half hour that all my crazy Google searches the past 6 months. Good info guys.:wink:
So I'm on my second Hemi swap, the last one was a first gen and turned out sweet, but after almost sliding her through a county fence, I decided to sell her while we were both still alive. So it's been almost ten years and I miss the little truck, sooo here we go again:stirthepo
Here's what I have so far:
'03 5.7 ram motor with a new bottom end and a valve job up top
'04 Shortbox with a 3.7 and a NV3500 (going manual this time)
So now here is the question of the day. I read on another thread an A/T NGC can be flashed to run the stick. I just wanted to verify this before I continue to scour the web for a R2500 M/T NGC. Does anyone out there have first hand experience with this and who flashed it?
Thanks again for the site!
· I hate you people.
I have heard the Hemifever can flash the auto PCM to manual but you will have to have an SCT tuner in order for you to do that.
I'll give them a call. Anyone else out there runnin a 5.7 M/T Dak? Thanks for the reply!
· Stroked 91
Before you go that route, I'm certain that HP tuners has the ability to flash the Auto PCMs. You need to grab an 05 Ram PCM, and it should work with all of the JTEC wiring. I'm in the process of gathering the remainder of my parts for my Hemi Swap into my 02 Quad Cab. I'm also going 5spd as well. Try researching modernmuscle.biz. Dave is the owner of the site and has performed many Gen III Hemi swaps into older muscle cars, and trucks as well. There are lots of good sites on the modern hemi, that should be able to help you out. Hit me up in a PM if you need more info. Also there are very knowledgeable members of this forum as well.
Discussion Starter · #5 ·
Whoo Hoo! I checked again and found dodge stuff. Last time I checked they just had Chev and Ford stuff. The only other grey spot in this thing is I want to put a R2500 clutch and flywheel in place of the 3.7/4.7 unit but info is sketchy there as well. Everyone runs the 545 with the swaps so the stick stuff is tough to find straight answers on. As far as the rest of the swap goes I have the kinks worked out. I kept good notes on all the mods I had to do to get the wiring and mounting done on the first swap I did. Thanks for the reply, I appreciate the help!
Discussion Starter · #7 ·
Ya, it was a sweet little truck. The only downside was the flaky paint that plagued the 90's. I'll hunt up some pics. The motor went in pretty easy. I narrowed a 9.25" rear from an '03 Durango for it because I didn't trust the 8.25" with the extra 100+ hp I picked up. The best part about it was letting people drive it who had no clue what was in it:).
Anyone have any info on the NV4500 clutch and flywheel set up?
· Premium Member
Here's 2 threads that might help you out between the 2. They are not exactly what you are doing but still might give you what you are looking for:
http://www.dakota-durango.com/forum/showthread.php?t=153267
http://www.dakota-durango.com/forum/showthread.php?t=157355
Good luck with the build!!
I would be interested in what you come up with for exhaust from heads down.
Discussion Starter · #9 ·
Thanks for the links, lots of good info. Your truck turned out nice! I'm guessing the hemi flywheel you used was from a car 5.7? I'd love a tremec, maybe after I fry the 3500 I'll go that route. I've read truck manifolds fit so I'll start with those then I've got a bender so I'll be runnin my own pipes with something Magnaflow out back. Haven't looked under there for clearance yet.
Here's some pics of the 93 I did.
· Premium Member
I am not sure if there is a difference between car and truck 5.7 flywheels but pretty sure mine is for car version if they are different. Here is the info on the one I am running:
FWCH-10013, SCIENCE FRICTION Billet Steel Flywheel, SFI Quality,
130t/10.5" for 5.7/6.1 Hemi, 8-bolt (weighed 26lbs).
I got it from American Power Train. I had MAJOR problems with their (Science Friction) PP. Ended up going with Center Force Dual Friction clutch/PP. Have many runs at track with slicks and 4k+ dumps with 0 clutch/flywheel problems.
Thanks for the kind words about the truck. It is a blast to drive :)
Nice job on the hemi transplant. Looks like you did a really good job!!
Now...just get then new one done ;-)
Keep us posted.
Discussion Starter · #12 ·
Thanks for the info. I was bummed when I saw Kiesler quit making the Dak kits, with your post a lot of the fuzzy parts of the swap disappeared so I'd be more willing to shell out the $ on a Trans to make it happen. It sounds like that was quite the fiasco with that PP, thanks for the heads up on that. This swap will take a little time to get done, but should be a lot more straight forward than the 93. Not to mention the bolt-in 9.25" rear end.
· Premium Member
If you decide to go with trans let me know, could save you between $1-2k and a lot of headeaches. I would have bought the trans outright and then sourced the parts myself. Both the flywheel and bellhousing I used on mine was "for" a 5.7. If I remember correctly the bell for 5.7 had starter on passenger side. Since 4.7 starter is on Driver side and I didn't feel like swapping all of the wiring around I ordered the 5.7 bell with starter on Driver side.
Which ever way you go you will have a blast when done!
Discussion Starter · #14 ·
I imagine I'll end up there eventually. That little NV3500 is gonna have a run for it's money behind a Hemi. Thanks again for the info.
Discussion Starter · #15 ·
So, thanks for all the trans input guys. I got her up and running with an extra V6 harness and a 2005 ram NGC. All the gauges are up and running, but it will be interesting to see how accurate the speedo is while reading the reluctor on the 3500 instead of the Getrag. I do lack the lower radiator hose. Any suggestions on which one fits well? I looked through the hose rack at the local parts store and with what they had I was going to end up putting two hoses together to make all the bends. I'd much rather do it with one hose:smile:
Discussion Starter · #16 · (Edited)
Well, I've been LOVIN my little hemi truck. Sounds great, 27 mpg on the free way and awesome acceleration. I did discover one problem... in third gear under heavy throttle... the tires stop smoking and the clutch starts smoking. Maybe I need a stouter clutch ;)? I think this should solve the problem.
Discussion Starter · #17 · (Edited)
I also thought I'd toss out some of the more useful things I found out with this swap. I got lots of unknowns answered in this forum, hopefully this info helps someone.
-The Hemi bolted right up to the 3.7L flywheel. Starter, clutch, NV3500 trans and all (Hence the smoky clutch). I'm sure the 4.7 bolts up the same.
-3.7 / 4.7L 02 sensors are different than the hemi sensors.
-The P/S pump from the Dak 3.7L isn't a bolt on but the R1500 3.7 P/S is if you swap the pulley to a 7 grove.
- 2.5" dual exhaust requires spare removal.
- If you are not careful, your dashmat will fall off in second gear.
I know the thread is old, but I wanted to post up some of this stuff to give back a bit. Challenger Tremec TR6060 swap in progress.
Reactions: 85octane
· Stroked 91
Wow, it's been a while since I've checked this forum.... Thanks for posting up the results you were able to accomplish.... I've considered doing a 5.7 hemi swap into my 02 QC dak that I did a manual swap on.... I may venture down this road next year.... If you don't mind, pm me what all you went through for the wiring aspect of this build. By this I mean the engine wiring harness.... I've got a 05 Hemi PCM, and 04 4.7 engine wiring harness that I can use to make this swap happen. I've also got several 3.9 wiring harness as well. Decisions decisions.
Discussion Starter · #19 ·
Pm sent. The swap’s a lota work, but I have a huge smile on my face every morning when I show up to work because of it. It really makes these trucks fun to drive.
· Stroked 91
I figured as much..... I've been gathering parts, and resources for the last 2 years to complete this swap. So far I have an 05 Ram PCM, HPTuners & MS3 (Have to figure out which one to run), 2 01-03 3.9 engine harnesses, 1 04 4.7 engine harness, a 04 hemi out of a Durango, 6.1 crank, and cam, several sets of heads, intakes, and tb's. Also have factory manifolds for the hemi truck. My biggest concern for this is the down time it will take to get the wiring completed for this swap. The rest seems fairly straight forward.
1 - 20 of 25 Posts
