Ok, The engine is swapped and not starting. The wiring harness is different than the harness on my crashed 2004 truck. The computer is obviously different also and they do not connect. I have read all this crap about changing from 32 pin systems to 16 pins system and vice versa. also heard about having to change cam sprockets or something. Where do I go from here. The harness in the existing 2001 truck with the 2004 motor all hooked up great. I had to take out a sensor on the intake and exchanged with the other mother so that the plug would connect and change throttle bodies because a sensor on the throttle body was different for the plug. Also took the power steering pump hose and exchanged it because the 2001 harness had a sensor that connects to the hose. so now all my connections are great. I am guessing that I will have to change wiring harnesses now to accept the computer that is still on my 2004 truck. can anyone chime in here with a direction I should head that is the most easiest way to get this thing started?How much of the harness do I ave to change and will I have to do any splicing? Primus, you seemed fairly knowledgeable about my situation. Whats the next move?
Well. I went ahead and changed out the wiring harnes and computer under the hood. I still cant get it started. I have only been able to connect 3 of the four plugs into the computer under the hood. The white plug routes to the head lights and the front if the truck then back into the fuse panel and back into the truck fire wall. This white pkug may contain something nexcessary to start engine. Thinking it may be easier to splice wires then to cjange fuse box and see whats behind the fire wall under the dash. Who knows maybe there is something i have t change under the dash. Can anyone help here? I am at ends and noone has chimed in for a while. Thanks
Here are pics of the computer and the old plug that needs to be replaced with new style. After going to thebfront end of truck, it goes the fuse box and then through the firewall. Like i said i havent seen what under dash and havnt had the time. I have about 25 hours into this truck and was just exhausted and it was getting dark.
Check out pics in my original thread
