Hi all.. I keep seeing all of these Hemi swaps with the Dakota's and Durango's that went very well for other people.. And I see that a few Companies that make the motor mounts and oil pan and pickup tube for the 2wds but not for the 4wd.. I just wish they made the motor mounts for the 4x4's as well..
I want to do this on my 04 crew cab 4x4 Dakota with the 4.7.. But I don't ever see any one use the BBK 80mm or 85mm Cable Driven Hemi 5.7L/6.1L/6.4L Performance Throttle Body 1791 that uses the Dakota and Durango TPS & IAC.. Witch should make the wiring a lot easier.. And with a cost of only $349 for the 80mm and $355 for the 85mm seems like a pretty good price. Cause then you could use the 4.7 Computer instead of having to buy a 5.7 computer as well.. And Just make the 4.7 wiring harness longer for the plugs that wasn't long enough. And just Change out the others that would not work..
I picked up an 04 Hemi with every thing as a Core motor Just cause I got it Cheap really cheap 200 bucks.. It has a hole in the block But I got it from the breather to the oil pan with all of the Engine and transmission and transfer case harnesses..
The motor that I am looking at is in a 04 Durango 4x4 that has a over heating problem but it is only 800 bucks.. There is no water in the oil or oil in the water and it only has like a 105K miles on it. And runs like a top other than that.. One of the Questions that I have is will I run into any problems with the Durango 5.7 rather than the 5.7 out of the Trucks? And by using the BBK one I can keep the Cruise control the way it is so post to work on the Dakota..
Buy going this route will I run into other problems by using the BBK 85mm Cable Driven Throttle Body? And by using a 04 Durango 5.7 Hemi? I am sorry about the long post.. I just have put a lot of time and money in the 4.7 and still have problems.. And one other thing What all Changed on the 09 and up 5.7 hemis? I do know where one of them is for 1700 that is low miles..
