1 - 6 of 6 Posts
Ty..This will be the 3rd time in 13 years I've changed it. Also installed a new wiring kit in it 2 years ago. Must be a typical dodge Dakota problem.
I had the same thing, replaced the resistor and burned up a year later. This time I replaced the motor and resistor. The motors go bad and pull more amps than the resistor can handle.
Yup.. I'll probably check the motor and replace it if I have to. It works great but with only high speed
It's getting up to 107 degrees here now also (cali)!!!
1 - 6 of 6 Posts
