check the connections on the wire for the low beam in the socket had the same problem with one of my fog lights it wasn't making a connection even though the bulb and everything else was good
start chasin wires! if it was the bulb it would have stopped when you changed them out. if it was the fuse, they would both flicker since they're on the same circuit. all you can do is grab and move the wiring harness and find out at what point you start duplicating the problem, then you know where to start looking for a broken or loose wire.
