Hello Everyone,
Thanks for stopping in...
I have a 2000 Durango 4X4
4.7L
I been driving it for two years with no problems...
few months back I started having problems with my battery gauge dropping to "nothing" and my check engine light would come on.....right around that time the blinker switch(relay) started making that annoying sound every now and then...
anyway's the battery gauge and check engine light ended up being a bad alternator. I got stuck driving it a couple times at night till the lights were about out and just made it home on the dead battery...blew a couple brake light fuses....alternator checked as good at local auto parts store, but it was not good...so I just replaced the alternator about a week ago...brake fuse has been fine since the new alternator (not sure if that could be linked to my problem or not).
now a week after the new alternator the blinker switch(relay) is never ending with that annoying sound they make...and blowing dash light fuses....
so I replaced the blinker switch(relay) up under the dash.....
NOW...
with the lights off, hit the brakes and the front left blinker comes on like a extra brake light...
hazards and lights work as they should. right blinker works as it should.
If I turn that left blinker on ALL my brake lights blink, even my 3rd light up high in the rear window, BOTH front blinkers and my radio lights(not the sound just the lights),my overhead display(temp,compass,etc)....my milage display and my gear display( P R N D 2 1) all blink with my left blinker...
Now turn the lights on....same thing as above but the radio, overhead display, milage display and my gear display( P R N D 2 1) no longer blink but my brake lights are on(all 3)not touching the brake pedal... but they will get brighter if I apply the brakes (so they're on, just not at full brightness).
I keep blowing dash light fuses....when the dash lights are on, the left blinker indicator on the dash is now on, but it also gets brighter when blinker is turned on....
tonight on my way home the dash light fuse blew again.....with the dash lights fuse blown, lights on(it's dark) hit my brakes and the front left blinker comes on with the brake lights...and my dash lights come on(with a blown fuse!!!) and my milage, overhead display, radio, gear indicator display all go out......let off the brake my milage, overhead display, radio, gear indicator display all come back on and the dash lights and front left blinker go off...
what is causing all this chaos?
did I fry something using the blinkers for so long with a bad relay?
driving on just the battery with the bad alternator? ( I heard that was bad).
I put a new dash light fuse in when I got home....checked all fuses and bulbs, and all are good.....
under the hood I have a trailer light fuse...I pulled that and nothing changed....(I assume factory tow package because it has the trailer light fuse)....
I'm at a loss.....
just too much chaos with all the lights going crazy. :devil:
sorry if that was confusing, but it is to me too :biggrin:
my lights have a mind of their own....
any idea's anyone?
4.7L
NOW...
I'm at a loss.....
any idea's anyone?
