2000 Dodge Dakota 4x4 - Cummins Turbo Diesel
90240 Views 94 Replies 41 Participants Last post by  jhyneman
11
Small project log for the truck I decided to build for myself. I prefer Dakotas to Rams but a Dakota never came with a diesel motor, let alone a 5.9L 6BT Cummins.
I started with a 1991 Dodge Ram D350 with a Cummins in it and with that I got the heart of the project, a 12V VE pumped Cummins.
I then bought a 1990 Dodge Power Ram W250 that was a Cummins truck but came with no motor. I used this for the rest of the drive train as is was Dana 60(kingpin) and Dana 70 truck with a large spline 727.
After cleaning up the frame and painting it I assembled the drive-train onto the frame and prepped it for the body.
For the body I bought a 2000 Dakota Quad cab that had a 4.7L in it(WORST MOTOR EVER) and ended up using none of it, lol. The whole truck basically went to the scrap yard. A local junk yard that I go to regularly had a black 2000 Quad Cab come in that was in much nicer shape. So with the help of friends we pulled the whole truck out of the yard(minus the frame) on their $60 all you can carry parts days. Its was a good haul to say the least.
After making my body mounts and box mounts it was onto modifying the body to fit the large inline 6. To do that the firewall had to be cut and a center section pushed 4 inches back. In order for the heater box to be retained it to had to be modified as well in order to bolt to the firewall. I had to cut and re-seal a mirror section of the heater box to the fire wall and then re plumb the heater core from one side of the box to the other(where the AC originally came in) so that it would clear the motor.
Then it came time to make the steering shaft(half Dakota, half Ram), the throttle linkage(Cummins cable with a crimp ball so that it would be tight using a Dakota pedal, and wiring harness. I used a stock Dakota engine harness so bring power to the inside of the truck and then made my own fuse block and added all the necessary circuits for the truck(power windows, power locks, and so on) I also had to build my own turn signal circuit, wiper/washer circuit, horn circuit, and gauge cluster. The truck uses no PCM as the motor is fully mechanical.
For the gauge cluster I opted to spend the money and build a full Autometer cluster. It was worth it, its easily my favourite part of the truck.
There is alot more I could keep writing about as to what I had to do to get it all to work but ill leave it at that for now. The truck is very close to done and now runs and drives.
It has been a long build but now seeing the light at the end of the tunnel its been worth it.
-2000 Dodge Dakota Quad Cab 4x4
-5.9L 12 Valve Cummins Turbo Diesel Swap
-A727 Torqueflite HD Trans
-NP205 Transfercase
-Dana 70 Rear Axle
-Dana 60 Front Axle w/ kingpins
-8 Bolt Hubs
-Skyjacker dual steering stabilizers
-Skyjacker shocks
-Derale trans cooler with fan
-Cobra CB
-Holset HE351CW Turbocharger
-Pure Performance 4" Downpipe, 5" stack
-Pure Performance 3" Intercooler Piping
-CXRacing Intercooler
-Pure Performance Intake Manifold
-DennyT fuel pin
-Injection Pump Turned Up
-Electric Fans
-Autometer UltraLite gauges
-PPF Body Lift and Mounts
-Hurst Shifter
-American Racing Wheels
and more still to be decided..............
21 - 40 of 95 Posts
damn man thats awesome
That is so damn sweet!!
My wife would kill me.
Very nice.
Put on a set of 37" HMMWV H1 military tires and wheels. Looks alot better.
http://youtu.be/zBTDKA4d_kE
Dieseldak, I know you modified your flares to fit, but what did you start with. I mean, what truck are they supposed to go on?
Sweet build man!
I was gonna say looks bad ass, but it needs bigger tires. But you already handled that. Love this truck, by far the most badass Dakota i've ever seen.
They are built off of 2003-2005 Ram pocket flares. just have to trim the hell out of them. Then cut 3" out of the top of your rear wheel arches.......and if you have a quad cab re clock and trim the fuel door. Its alot of work but definitely worth it. It gave the truck a whole new look.
Yeah I will have to lift the truck another 4" to get it to sit where I want and maybe a set of 39s or 40s in the future. But the 37s look good for now, alot better than the 33s that were on it.
Nice truck. Very bad ass
Nice work! You have much more drive to get a project started and done then I could ever think about.
7
All the snow melted ruining any chance or going snowmobiling so me and a buddy took out the beaters and snapped some photos....
god dammit. i just had to see those fender flares. 430 bucks too.. looks sick.
don't take it personal but i kinda hate you right now:D nice truck!
Yeah, the install isnt for the faint of heart...........lots of cutting and trimming but its worth it. Ive never seen a Dakota other than mine with them.
yea i had that idea in mind for years. just never knew which flares to get and start modding them. maybe if i get lucky ill find a used set.
Yeah, me too. Once I did this swap and was driving around on tiny ass 33s I knew I would need to go to a bigger tire and they would be sticking out way past the factory flares. I had to do something so I went out at night to all the dealerships with a tape measure, pen and paper. I measured a 1994-2002 Ram, a 2003-2009 Ram and a 2007-2012 Silverado. The 2003+ ram was the closest so I went with it. All you need to do it is a grinder with a flap disc(to re shape the flares), a metal cutting disc(to cut the rear wheel wells) and a box of 3/8"x2" self tapping screws(to attach the flares).............
This thing is the definition of awesome... I'm speechless. Wish I had the mechanical ability to do this!
21 - 40 of 95 Posts
