Got a 2000 Dodge Durango with the 5.9 Magnum. Go to fire it up the other day and it just says check gages not throwing any other codes. My volt meter is a little low so I charge the battery still says check gages crank it over and over finally starts but it's rough RPMs go from 1000 to 500 idles but I don't have any throttle response then just dies.try to get it to start back up nothing so I start checking fuses I blew an alternator fuse so I replace it get it to fire back up with starting fluid idles for a minute that's when I noticed no oil pressure check the oil it's full can't get it to fire back up when I try and the gauge shows oil pressure it almost acts like it wants to start but when it doesn't show any pressure it doesn't even sputter.and leads at this point would be great
