2001dakotaR/T said:
Did you buy the whole hotchkis kit or just the leafs and front springs?
Getting the front coils, and the rear leafs is practically getting the whole set up.
The Hotchkis kit is going to give you a STIFF ride. By stiff I mean STIFF. It can give you a .93 in the lateral G, and most corvettes only get a .91. SO... if you are not wanting to give up your ride quality, this is what I would do.
1) Cut your front coils an inch. This will decrease the height by one inch, and won't kill your ride up front.
2) Get shackles or hangers... I can't remember which one makes your leafs go upward into your bed, this will lower your ride, but keep you with the same ride quality that you have right now.
Cutting your coils is a risky thing, cause you can never put it back on,... but it is relatively cheap considering all you'll need is a torch of some sort.
The Shackles and hangers will cost you a lil bit, and also cost you some good work, cause you'll need to drill out some rivits... I think 6 if I'm not mistaken... maybe 8.
This will give you the same quality ride you have now, and will lower your ride at the same time. I wouldn't spend money on getting the hotchkis if you are pretty sure you won't like the ride, because hey... you can spend a 1/4 of the price to drop it... and the rest of that money on 20's.
I hope this helps you man... if you have any other questions, just post.
Paul
