Generally motors from the 50-70s where tired and ready for retirement after 80k or so milessp youre sayin that engines from the 60s/70s aren't capable of going that far before a rebuild?
I'd much much rather have cam in block pushrod V8 than 4 timing chains scraping on plastic guides (that like to break without warning)
not to mention metal instead of all the plastic BS of todays engines... from what I have seen all this cheapening and electronic brains has done damn little for mileage to boot
Bought mine in Jersey 2 yrs ago than moved to Knoxville, so I'm in east Tennessee. Got it with 182,000 and now it had 217,000. Running very strong. Clutch fan delete has been the best mod so far.214k on my 2001 SLT 4x4 w/ 4.7L. I bought it new in PA...1 year in the winter and then moved to western Tennessee. No mods other than Powerstop drilled/slotted rotors on the front (no more rotor warping) and 70+ oil changes using Castrol 10w/30. Shooting for 300k.
Can you elaborate on the Cat Fire? What happened and how? I basically have the same setup as you, and running just short of 200K, just would like to know the details of what lead up to the fire, especially since you said it was serious, although any Cat fire I would consider serious.Wow guys great infoJust did a engine block test though and it came back yellow
Trying to decide what to do next. Head gasket or new engine.....
When the truck started acting funny I didn't drive it and still havent driven it. I only ran it for the testing. So I might give it a shot. I'm only an mid level mechanic but i've already done the heater core, timing chain/gears, plenum and had one serious catalytic converter fire. So I think i'll give it a shot![]()
PLEASE PLEASE DO A WRITEUP WITH PICTURES! I am sure everyone on this forum would benefit from a how to on head gaskets or a plenum replacement. I am confisdering tackling the plenum myself but I cant find a step by step with pictures or video of how to do it...Wow guys great infoJust did a engine block test though and it came back yellow
I beleive that cat fire started because of a random misfire I was chasing down. Turned out to be a really loose / slapping timing chain. But anyways, We think the hunny comb broke down and fuel was running down to it from the misfire and it just went cherry red and then changed to on fire. I was actually pumping gas into the truck when I smelled the bumper meltingCan you elaborate on the Cat Fire? What happened and how? I basically have the same setup as you, and running just short of 200K, just would like to know the details of what lead up to the fire, especially since you said it was serious, although any Cat fire I would consider serious.
Also the engine block test, you say came back "yellow" was that an oil sample test? Not sure on what you mean, interested in that also, Thanks!
Alot of people recommended that I go with a Hughes Plenum kit, which I did and havent had a problem sincePLEASE PLEASE DO A WRITEUP WITH PICTURES! I am sure everyone on this forum would benefit from a how to on head gaskets or a plenum replacement. I am confisdering tackling the plenum myself but I cant find a step by step with pictures or video of how to do it...
Thanks for getting back with me on this. I'm glad it worked out for you, well as best as it could have. I realized after I asked the question that the post was quite old and never really expected a response. As far as the misfire I just got through replacing my timing chain among a lot of other items, so it's good to know that all my work wasn't done in vain, Thanks Again.I beleive that cat fire started because of a random misfire I was chasing down. Turned out to be a really loose / slapping timing chain. But anyways, We think the hunny comb broke down and fuel was running down to it from the misfire and it just went cherry red and then changed to on fire. I was actually pumping gas into the truck when I smelled the bumper melting![]()
Update:214k on my 2001 SLT 4x4 w/ 4.7L. I bought it new in PA...1 year in the winter and then moved to western Tennessee. No mods other than Powerstop drilled/slotted rotors on the front (no more rotor warping) and 70+ oil changes using Castrol 10w/30. Shooting for 300k.
