My 1999 RC 2.5L I4 has a peculiar problem. It won't start or run if the air is wet from any consistent amount of rain. Even sitting, not run, no leaks, etc. After a day or two of heavy rain the engine will not fire up and run. I might get some (mis)fires when cranking, but it will not start. If it ever does start, it will run very poorly, then die - never to start again until it has been warm and dry for days.
It would seem to be an ignition problem, and most likely the distributor is collecting moisture which condenses and fouls up the electronics in the distributor. Questions: 1) has anyone else had this trouble and what did you do? 2) would this be as simple as a cap replacement? 3) is there perhaps a seal missing on the cap or distributor that I should look for/verify?
Thanks!
Thanks!
