You sure I thought it just measured the heght of the tire? Well thye are 255/55/R18's anyways.
yup, he's right. incase you didn't know, the middle number is a percent of tread width.
when they say a tire is 255/55/18, that means:
255 = tread width in millimeters
55 = sidewall height, as in, 55% of 255
18 = rim size.
so, a 255/55/18 is 29" tall, with a sidewall height of only 140.25mm and a 235/55/18 is only 28.1" tall, with a sidewall height of only 129.25mm.
you might want to check that quote...i never stated that...yup, he's right. incase you didn't know, the middle number is a percent of tread width.
18 = rim size.
I know what you said. you said "55 doesn't mean anything without the width"you might want to check that quote...i never stated that...
so then mthandt said "are you sure about that? I thought it was the sidewall measurement"
all I did was click "quote" from mthandt's post, so not sure what happened there.
18 = rim size.
Good to know, thanks for the info rainman.:jester:
Exactly why I posted what I posted above...lolHoly hell those are 18's???? They look like 15's...
Where'd you get em?yes, those are 18 inch MB express wheels
It used to be Discounttire.com but I believe they are discontinuedWhere'd you get em?
