I have an 05 Durango 4.7L V8. I recently needed to replace my fuel pump & during the holidays I didn't work on it at all. So I got a new pump & put it on & now it won't crank. I pulled the pump & checked to make sure it worked. I've blown out my fuel lines, I've checked all my fuses & relays. There is no reason for it not to start. A buddy told me to check the security board since I had not been using my FOB (but I am now) & I don't know where the security board is or what exactly I'm looking for. Can someone please help.
C'mon Dodge - NEW DAKOTA
The fuel pump has nothing to do with cranking. There are a number of interlocks that can prevent cranking -- the main one being the gear selector. You must be in Park or Neutral to crank. The shift selector might indicate Park but not actually be in Park... so start with that. Do you hear anything when you attempt to crank? A relay or solenoid clicking?
Its in park. I hear the fuel pump motor for about 4 seconds & the relay under the hood clicks twice as soon as I turn the key & then clicks one more time when the pump turns off.
I'm not familiar with that gen Durango but if it's like most vehicles, there is a relay that powers the starter solenoid. Have someone monitor the voltage at the starter solenoid (mounted at the starter) with a voltmeter while you turn the key. That will not be the terminal with the large wire going to it --- it will be a smaller wire. If voltage appears there with key in the start position, then you have narrowed the problem to the starter itself or the solenoid. In either case the remedy is the same -- change out the starter. If voltage never appears there, then the problem could be in the starter relay, or some other interlock, including the security system, or the wiring or connectors between the relay and the solenoid.
