ok ive only had this durango for 2 months. i had fuse tapped the cig lighter fuse to hard wire a backupcam to run whenever truck is running using a fold down lcd in center overhead. worked fine for weeks. then shut off. fuse blew. replaced. immediately blew again. stopped to buy fuses. when i went to start nothing. this was outside an actual auto parts store. coulda been a bad ground blowing fuses but im assuming this created a bigger prob. turn key nothing. headlights come on full. no dash lights. gets power to windows locks cig lighter . wont crank . tested batt. good 94% checked all inside fuses. ok. checked relay box under hood. when turn key the rear blower motor relay clicks. when you touch it you can feel it is deff the one clicking. bought a new one. same thing. tried swapping relays for ASD just to troubleshoot. nothing. so. replaced starter. nothing. same thing. used a multimeter to check relays per online instructions for continuity and seem ok. WHY is the rear blower motor relay involved in this ??? where do i check next? and the fuse tap was removed from the equation in the first step so its out of the mix.
