I just bought a Durango that was not running. They said the dealer said the PCM was bad because the alarm would not turn off.
I replaced the PCM.
I unlocked the door with the key
The alarm stopped beeping
I started the truck
It died
I started it with my foot on the pedal
It runs but dies if I let go and it is rough
It has plenty of fuel in it, but after it runs for about 45 seconds the gas gauge drops to zero and says low fuel.
The securtiy light flashes the entire time.
Any advise and to what to try next? also no check engine lights but the battery was just hooked up because of the alarm going off and I don't know if it has had time to set a light.
This is the first 4.7 durango I have had and I am not really sure if it is normal or not for the security light to flash.
Also when its idling rough the rpms go up and down alittle
I replaced the PCM.
I started the truck
It died
