Axle Swap Questions - Dakota Durango Forum
Suspensions - Lifted & Lowered Drop Kits, Lift Kits, Shocks and More
post #1 of 4 Old 12-14-2015, 12:13 AM Thread Starter
andrewlyledugan
andrewlyledugan's Avatar
Vehicle: 1990 Dodge Dakota
Modifications: Carb Converted 5.2 Magnum. Originally a 2.5L K-Series motor
Quoted: 0 Post(s)
Garage
Axle Swap Questions
Alright Guys so I have a 1990 Dakota that was originally a 2.5: 5 speed truck. I swapped a 5.2L and a 5 speed in it now. So i just kept the Chrysler 7.25 rear end in there for a while and its really been holding up great, i've even changed the gear oil and everything is looking good but i cant rely on it all the time and the aftermarket isnt very large for it.. anyway I found a Chrysler 8.25 rear on a 1989 Dakota and i had to snatch it up. Now comes the problem... The 8.25 sat under the leaf springs and the 7.25 sits on top of the leafs.. Im trying to lower the truck and I need the axle to sit on top of the leafs so i would appreciate a solution (as cheap as possible because i am a college student) and as for my next question is will i need to shorten the drive shaft? im assuming i will but if i dont have to then ill avoid it. I know this isnt technically a lowering or lifting question but i chose the closest thing to drive line. Thanks guys
"If you ain't first your last" -Ricky Bobby
andrewlyledugan is offline
Sponsored Links
Advertisement
post #2 of 4 Old 03-03-2019, 11:21 PM
4Lo
Frog Legs
4Lo's Avatar
Vehicle: 2003 Dakota SAS CC 4X4
Quoted: 16 Post(s)
Cut off the spring perches and weld on new ones where they need to be. Then phone your local driveline shop and ask them how to take the measurement to custom fab or shorten your driveshaft. Its really not that difficult. Are all of the brake fittings and emergency brake cable connections the same between both axels??
Edit: please please buy new ubolts when doing this job. Believe it or not they do stretch and reusing old ones could have disasterous consequences.
My axle swap thread.
http://https://www.dakota-durango.com/forum/showthread.php?t=142709
2003 Dakota SAS Dana 44, 9 Inch, 35''tires, ARB and 4.88's
4Lo is offline
post #3 of 4 Old 03-04-2019, 02:41 AM
RXT
Vehicle: 99 Dakota
Modifications: Quad Cab swap, Cummins swap, Solid axle swap
Quoted: 127 Post(s)
Well by now, the OP either resolved his problem, sold off the truck or abandoned the vehicle….seeing that you responded to a 3 yr old post
Ed
6BT, 3200GSK, M&H#3, W/A IC, 5X.012, AirDog100, HE351.
RXT is offline
post #4 of 4 Old 03-04-2019, 02:47 AM
4Lo
Frog Legs
4Lo's Avatar
Quoted: 16 Post(s)
Quote:
Ed
Haha yup. I havent been on here since 2015
4Lo is offline
Sponsored Links
Advertisement
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
User Tag List
Linear Mode Linear Mode
You may post new threads
You may post replies
BB code is On
