Will a 318 from a 99 Durango 4x4 swap into my 2000 318 4x2? - Dakota Durango Forum
5.2L/5.9L/6.7L Engines Questions regarding the 5.2L/5.9L/6.7L V8 Engines
post #1 of 6 Old 07-21-2017, 04:58 PM Thread Starter
Metrix
I have a 2000 4x2 Durango with the 318 Magnum that I'm looking to replace the motor in. I found a 99 Durango with a 318 Magnum so I'm curious if it the motors are the same or if I will have to modify or replace anything.
Metrix is offline
post #2 of 6 Old 08-04-2017, 07:09 PM
willspotter
willspotter's Avatar
Should be a straight swap.
willspotter is offline
post #3 of 6 Old 08-04-2017, 11:32 PM
OFWG
Quoted: 38 Post(s)
You'll need the engine wiring harness and the PCM from the '99.
OFWG is offline
post #4 of 6 Old 01-19-2018, 01:36 AM
bloodsmear
No, he would need to keep and use the wire harness from his 2000, the trans plugs are different.
bloodsmear is offline
post #5 of 6 Old 01-19-2018, 12:58 PM
OFWG
Quoted: 38 Post(s)
The '99 has EV1 injectors which have the rectangular shaped connector and the '00 has EV6 injectors which have the oval shaped connector. If the OP keeps the '00 harness he'll need to buy adapters for the connector plugs.
OFWG is offline
post #6 of 6 Old 09-15-2019, 03:51 AM
donram360
Vehicle: 93 clubcab 318 5 speed
Modifications: 5 speed swap, will drive it til it dies
Quoted: 18 Post(s)
or swap injectors?
caution: still plays with carburetors!
donram360 is offline
