Removing crank shaft position sensor - Dakota Durango Forum
post #1 of 12 Old 10-26-2009, 09:13 PM Thread Starter
dbilik
dbilik's Avatar
Vehicle: 2001 Dodge Dakota QC
Any tips on removing this? It is a pain so far, and I cracked the first one trying to get it out. Thanks.
dbilik is offline
post #2 of 12 Old 10-26-2009, 09:21 PM
AIR_RAM
www.AIRRAM.com
AIR_RAM's Avatar
Vehicle: 2002 QC RAM 4.7L *SOLD*
Modifications: 2011 Grand Sport Corvette :)
Quoted: 6 Post(s)
I mangled mine when I went to check it... LOL ... So needless to say after I was done looking at it I needed to buy a new one. Sometimes they come out with some constant pulling.
There is a rubber O-Ring that sets in pretty good. You need something that can grip it and pull with constant pressure... If you let off the pressure it just snaps back into place. I tried to use a screw driver on the one in my truck and that just bent the tab for the bolt that holds it.
They come out... just a PITA sometimes.
SPEED SAFE, AIR RAM
AIR_RAM is offline
post #3 of 12 Old 10-27-2009, 08:46 AM
razman131
Home Owner....
razman131's Avatar
Vehicle: 1999 Dakota R/T
Modifications: to many to list, plus standard bolt ons and suspension mods.
Send a message via Yahoo to razman131 Send a message via Skype™ to razman131
pull the fender liner... easier to get to. gotta lift it straight up or it is a PITA to pull out.
1999 Dakota R/T (mild to heavy mod)
2006 Magnum SRT8 (not *yet* modded)
2004 Dodge Caravan SXT.... Momy Mobile
BEATER: 1991 Honda Civic DX 4dr
razman131 is offline
post #4 of 12 Old 10-30-2009, 03:53 AM
scjeep4.7HO
scjeep4.7HO's Avatar
Vehicle: 97 dakota, 04 G. cherokee
Modifications: 2004 Grand Cherokee. Supercharged 4.7L HO, cammed. meth injected, SCT tuned, 72mm F&B throttle body, 180* T stat, Magnaflow exhaust, Trans go shift kit W/ deep trans pan.
On my jeep I had to take the starter loose to even have a chance. It was very tight, but some cursing and constant arm contorted pulling freeed mine unharmed.
Paxton NOVI 2000 supercharged Jeep 4.7L HO, Cammed, Heads, Built Motor, Custom COG supercharger drive sysem, Custom ATI dampner w/ custom cog pulley, Both Sheet metal intake or stock intake, Turbo Smart race port BOV, 72mm F&B throttle body, Meth injected, SCT tuned, 60# injectors, Billet fuel rails, full Fuel system, True dual Exhaust W/Magnaflows, Iridium plugs, Built Transmission W/Trans-Go shift Kit, Deep trans pan W/Trans cooler, 180* T stat, 275 60 R17 rubber, ETC....
scjeep4.7HO is offline
post #5 of 12 Old 10-30-2009, 08:56 AM
razman131
Home Owner....
razman131's Avatar
not a problem on the Dakota.... starter is on the drivers side. tho it is still a PITA cuz of the clearance and the AC drain is also there.
post #6 of 12 Old 10-01-2010, 09:36 PM
judgesherpa
Vehicle: 01 Dakota QC
Use 2 small screw drivers to ROCK it out. there is an oring that gets sticky after a few years. and definitely remove the fender liner
judgesherpa is offline
post #7 of 12 Old 10-01-2010, 10:19 PM
frmboybuck
frmboybuck's Avatar
Vehicle: 2000 Dakota Quad cab 4x4
Mine was froze in to the point that I had to use a screwdriver and hammer to chisel it away.....completely. Mine was a bitch. Cleaned the hole out good with a wire brush and still had to drive the new one in with a block of wood and a hammer. I have had to drive them in before and remove the oil pan to retrieve them.
frmboybuck is offline
post #8 of 12 Old 10-02-2010, 10:01 AM Thread Starter
dbilik
dbilik's Avatar
This was an old thread to revive. I got that thing out like a year ago.
dbilik is offline
post #9 of 12 Old 10-03-2010, 05:16 AM
Jasoon
Jasoon's Avatar
Vehicle: 2001 Quad Cab Dakota 4x4
Did you take any pics? I'm throwing a code and I believe I'll have to replace this soon.
MOPAR THUNDER...2001 Dodge Dakota Quad Cab 4x4, 4.7L V8, 120,000 miles.
Still passes the 8 foot test.
In search of a fiberglass tonneau Cover
Jasoon is offline
post #10 of 12 Old 10-03-2010, 03:22 PM
l1tech
Vehicle: 02 Dakota CC 4.7
A liberal shot of penetrating oil while twisting and pulling and these things come out in a hurry....
l1tech is offline
post #11 of 12 Old 12-18-2014, 02:50 AM
TheNonMechanic
I twisted the sensor clockwise, then looped a long and strong shoestring around the sensor and underneath the metal arm. I wrapped the free ends of the shoestring around a wrench and then yanked on the wrench, each time pulling a bit harder. The sensor popped right out, after a few strong yanks. I did NOT take off the fender liner. Also, when installing the new sensor, I used a block of wood and hammer (as mentioned by frmBoyBuck), which worked quite easily.
TheNonMechanic is offline
post #12 of 12 Old 06-23-2016, 06:23 AM
cmatheny1
Bumping...just removed (what I think was) the original sensor from a 2001 Dakota. Mine eventually came out in a 100 pieces. I tried every method suggested on the internet, would not so much as budge. Took me a full week to get the d#&n thing out using a few hours in the evenings each night:
Prep: Jack up truck, remove passenger tire, remove wheel well cover. Sensor is accessible directly from the passenger wheel well. Spray liberal mounts of PB blaster, let it sit, spray some more.
a) Wiggle it back and forth with two screwdrivers (lmao....uh, yeah right, no movement at all)
Spray liberal amounts of PB blaster.
b) Grabbing with channel locks, prying hard by hand. (no movement, not even close)
c) Wrapping a cord around it, tie the other end to a heavy object, and yanking (i.e. a slide hammer). Nope, no movement, not even close.
Now I'm cursing....and spraying liberal amounts of PB blaster.
d) Grab it with bigger channel locks again, prying harder this time with the expectation it either comes out or it breaks.
It broke off flush with the engine block...no movement at all.
More cursing....
e) Go to store, buy some long drill bits (in this particular case, size matters), drill a pilot hole, insert a heavy duty concrete anchor screw, wrap some steel wire around it, wrap the other end around a crow bar, rest the crow bar on the truck frame for good leverage, put full weight on the crow bar to pry it out.
SNAP! Wire broke.
MORE CURSING....
f) Using a drimel, clean up the outer edge of the hole in the block, then go to store, get heavier wire. Rinse and repeat,
SNAP! That wire broke too.
No movement at all from the sensor. Now I'm getting pissed, and looking for someone other than myself to blame for this insanity (Chrysler perhaps?)
Spray liberal amounts of PB blaster....I'm getting good at aiming the can.
g) Using the long bit, drill little holes around the outside of the sensor.
Crow bar and wire trick round 3. SNAP! Wire breaks again.
SERIOUSLY!?!?!?
h) Ok, time to switch tactics....turn on the compressor, hook up the air hammer, and pound away. Voila! About 2 hits by the air hammer and the sensor MOVES!....in the wrong direction of course, into the block.
But not all the way, so I think to myself, it moved, so this booger is coming out!
i) Using the drimel again, now I have much more of the hole exposed and give it a good few rounds of drimel care...this hole is now clean and smooth. Crow bar and wire trick round 4. SNAP! Wire breaks again. Now I'm thinking, what the, this thing just moved, it can't still be stuck! But alas, it was indeed....more pulling and yanking and prying. No movement.
j) Go to store, get a bigger long drill bit. Drill most of the inside of the sensor completely out (but not all the way through otherwise you push pieces of sensor inside your engine block). Run a vacuum cleaner over the hole to keep it clean of debris (again, junk in the engine block = bad).
Note: At this point, little remained of the actual sensor as I had little holes drilled around the outside as well as a large chunk of the center drilled out.
k) Crow bar and wire trick round 5. SNAP! But not the wire, this time out comes the screw, and half of the sensor with it (which had now split in 2).
Now I'm both rejoicing and worrying as to whether any pieces fell into the block....I run the vacuum cleaner again and pick up pieces and parts from the hole.
l) Run vacuum over the hole (worth repeating....hard loose objects inside engine block = bad), use a hammer and long flathead screwdriver, chisel the remaining half off the side of the hole, grab it with needle nose, pull hard, and VOILA!, out came the rest, and I now had an open sensor hole.
j) Run drimel to clean the hole, insert new sensor, put everything back on, and...here comes the best part:
It didn't fix my problem!!!!
Roll eyes, curse uncontrollably, throw tools, binge drink, kick the dog.....before,
l) Calming down, ordering a PCM/ECU off e-bay, installing it in 5 minutes, and fixing the actual problem.
My random stalling and no start problem was the PCM/ECU, not the crank (or cam) sensors. Food for thought for anyone contemplating a 15 year old crank sensor as a DIY fix.
cmatheny1 is offline
