Cummins 4BT Engine swap? - Dakota Durango Forum
Gen II Dakotas 1991-1996 Dakota-Specific Questions
Thread Tools Rating: Thread Rating: 4 votes, 5.00 average. Display Modes
post #1 of 5 Old 09-24-2009, 02:51 AM Thread Starter
AlightBULLDOG
MOPAR or NOCAR
AlightBULLDOG's Avatar
Vehicle: 96 Dakota 3.9L V6M 4x4
Modifications: 2-3'' tortion keys, K&N pie air filter/lid filter, Botch Platinum+2 plugs, Borge Warner wires, Accell power coil, ARacing 15x8 baja chrome aluminum, TB Spacer 4.10 Yukon's.
Cool Cummins 4BT Engine swap?
I wanted too know If anybody out there has done a engine swap with a cummins 3.9L inline 4BT diesel engine!? If so what mods were done to to make it work, & fit into the dakota?
For those who want to know about this engine here are some facts.
Cummins came out with a 3.3L, & 3.9L Inline 4 cylinder diesels both B series motors, & called them the 4BT, & 4BTA. The 4bta is the newer gen motors.
The 3.3L is about 550Ib wet, & had 89hp, & 215Tq.
The 3.9L is about 750Ib wet, & had 130Hp, & 355Tq.
Both engines are cominly found in many step van applications such as frito lay, & bread trucks. The 4BT today is also popular as a conversion engine among many light-duty pickup trucks that were originally equipped with gasoline engines. Many have reported getting as much as 25-35 mpg.
The 4BT engines have the same pistons, connecting rods, valve train components, and injectors as their 6BT counterparts. The 6BT is the cominly found inline 6 cylinder 5.9L & the late 6.7L.
I have a 3.9L V6 Magnum stock rated at 175Hp & 220Tq & getting about 17 mpg.
Making the change to the 3.9L 4BT I would lose 45Hp & gain 135Tq.
A guy with a 4BT ranger ran a 8.27 at the strip. Here is the URL http://www.youtube.com/watch?v=yxnfY...layer_embedded
96 Dakota 3.9L V6 Magnum 4x4 + Accell Super Coil + 8mm BW + BW Cap/Rotar + Botch Platinum+2 + K&N & Summit Xstream Lid + 50mm 318 TB + 4.10 Yukon's + AR Baja 15x8 Polished Alluminum + 31x10.50 GoodYear Wranglers A/T + AUX Fog Lights!!
AlightBULLDOG is offline
post #2 of 5 Old 09-24-2009, 05:43 AM
Hahns5.2
No Boost? Why Drive?
Hahns5.2's Avatar
Vehicle: 95 Dakota Sport
http://www.4btswaps.com/forum/showth...ghlight=dakota
5.2, 5 Speed, MS3X (Full Sequential, Spark, Idle, Boost Control, Fan, Water/Meth), HX40 Pro/P-Trim Hybrid.
Hahns5.2 is offline
post #3 of 5 Old 09-24-2009, 06:08 AM
Trouble Maker
Trouble Maker's Avatar
Vehicle: 02 & 03 Dakota Quad Cabs
Here is a link to a guy that did a 4BT swap into a 94 4X4 Dakota in Edmonton, Alberta, Canada.
http://www.na4wda.org/index.php/topic,1593.0.html
Russ
His-SASed 02 Dakota Quad Cab Sport 4x4 4.7 NV3500 5spd/Std D44/9.25" 4.88s lockers frt/rr 35" ProComp Extreme MTs frt EPi 9k Superwinch rear LP 8.5k Superwinch
Also his: 09 Power Wagon Hemi 4.56 gears 285/70R17 Duratracs factory winch and lockers
Hers-03 Dakota Quad Cab Sport 4x4 4.7 545RFE 5spd/Auto 3.92 L/S 265/75R16 Dueler RVTs 5th wheel hitch
Trouble Maker is offline
post #4 of 5 Old 09-24-2009, 06:24 AM
Trouble Maker
Actually he is located just west of Edmonton in Stony Plain, here is a link to his homepage with all the Dakota swap pics.
http://www.khaoskustoms.ca/aspx/blob...x/msgid/443167
Russ
post #5 of 5 Old 09-24-2009, 07:14 AM
SEG388
Vehicle: .
6BT-Dakota (a member here) did a swap too, except he did it with a 6BT
Good thread too:
http://www.dakota-durango.com/forum/...ad.php?t=77610
SEG388 is offline
