Help me identify this oil leak! - Dakota Durango Forum
Thread Tools Rating: Thread Rating: 4 votes, 5.00 average. Display Modes
post #1 of 8 Old 09-06-2009, 09:54 PM Thread Starter
SKDakota
SKDakota's Avatar
Vehicle: 04 DAKOTA
Alright i have clarified that this is not leaking from the back of the valve covers downward. My oil level has been depleting a small amount recently and i believe it is from the back of my oil pan gasket. A trans leak from this area doesn't seam too likely. The picture was taken less than 24 hours since i decreased and rinsed the oil pan area. Could some one please help me confirm that my oil pan gasket is the leak shown. Thanks guys!
2004 Dakota 2wd-K and N intake/Flowmaster 50 delta
Suicide doors Dakota bolt in mini notch welded in
3" springs 4" blocks- Energy bump stops
Belltech nitro 2 drop shocks
boss 330 20" rims wrapped in Falken Fk 255/45's
SKDakota is offline
post #2 of 8 Old 09-07-2009, 01:52 AM
45AutoPete
Vehicle: 2002 Dodge Durango
If you notice a leak coming out of the hole between your rear housing and transmission on the bottom, it might be a rear main seal. Since you said your oil level is going down, I would look real close at the hole to see if it is dripping out of there. Otherwise, it would be the pan gasket. I cannot remember if the rear of the pan gasket is part of the rear main seal too, maybe someone else would know.
45AutoPete is offline
post #3 of 8 Old 09-07-2009, 07:27 AM
razman131
Home Owner....
razman131's Avatar
Vehicle: 1999 Dakota R/T
Modifications: to many to list, plus standard bolt ons and suspension mods.
Send a message via Yahoo to razman131 Send a message via Skype™ to razman131
the oil is below that pan gasket.... so i doubt it is coming from there. rear main seal is more likley.
make a trip to the local Vautozone and get some oil dye and a black light.... that will show the leak.... tho ya need to change your oil soon afterwards.
1999 Dakota R/T (mild to heavy mod)
2006 Magnum SRT8 (not *yet* modded)
2004 Dodge Caravan SXT.... Momy Mobile
BEATER: 1991 Honda Civic DX 4dr
razman131 is offline
post #4 of 8 Old 09-07-2009, 08:26 AM
muddigger4x4
MUDDIGGER
muddigger4x4's Avatar
Vehicle: 1999 Dodge Durango 5.9L
Modifications: opened exhaust slightly future change coming
Send a message via Yahoo to muddigger4x4
imma guess rear main from those pics, not sure, good luck
RIP 5.9L Magnum
5 door whore #155
muddigger4x4 is offline
post #5 of 8 Old 09-07-2009, 02:51 PM
johnpittbull
johnpittbull's Avatar
Vehicle: 2000 Dodge Dakota Quad
Modifications: K&N CAI, 03 front brake upgrade, 16" wheels, clear headlights
I would more and likely say rear main seal leak as well.
2000 Dakota Quad Cab 2wd; upgraded front brakes to 2003/04's, K&N CAI.
johnpittbull is offline
post #6 of 8 Old 09-07-2009, 04:38 PM Thread Starter
SKDakota
SKDakota's Avatar
Vehicle: 04 DAKOTA
Alright guys, Is it worth getting the manual for the 4.7 to do the rear main seal? Could some one please tell me a little more about what doing the real main seal will involve and the best way to go about doing it? The oil leak seams to be pretty concentrated from the 2 holes in the rear housing so by the sounds of it its the main seal. From my understanding i will have to drop the transmission to complete this act, Could some one please explain the best way to complete this repair. from my research i need a special dealership seal puller tool as well as a special dealer ship tool to set the new seal.
pulled the inspection cover and i could see a drop of oil coming off where the crank connects to the flywheel so it MUST be the rear main seal.
THANKS
SKDakota is offline
post #7 of 8 Old 09-08-2009, 07:37 AM
razman131
Home Owner....
razman131's Avatar
good luck....
if anything, your pulling the trans, oil pan and flywheel..... worst case, pull motor and put on engine stand....
depends on how the seal goes in....
post #8 of 8 Old 09-09-2009, 03:16 PM
SolidStateS15
SolidStateS15's Avatar
Vehicle: 01 Dakota CC 4.7L 4x4
Send a message via AIM to SolidStateS15
i have a leak close to that area as well, but mine looks diff being a 5spd. i was also thinking the rear main, but i'm not losing enough oil to worry about right now. it's a very slow leak, but enough to make everything wet under there. i never show low on the dip stick level.
- 01 Dak CC 4.7L 4x4 5spd MT, DD
- 85 Toyota Supra MKII, Project car
- 09 Toyota RAV 4, Grocery getter
SolidStateS15 is offline
