Billowing white smoke from exhaust - Dakota Durango Forum
post #1 of 12 Old 08-02-2009, 05:42 AM Thread Starter
UberFr0g
UberFr0g's Avatar
Vehicle: 98 dakota sport
(searched but didnt find these symptoms)
I went out to move my dak (3.9) a minute ago and noticed it was billowing white smoke out of the exhaust while idleing. I drove it earlier today with no problems or power loss, and it started just fine now.
I checked the oil...seems ok, not milk-shake like or anytnhing. The coolant level seemed fine. Funny thing is the oil pressure at idle sits about 3/4 of the way up....no idea whats causing that.
Please don't say blown head gasket, im in the process of saving to have my stratys r/t head gasket replaced....
ps: exhaust smells like normal exhaust...not sweet or anything.
98 Deep Amethyst 5 spd 3.9
UberFr0g is offline
post #2 of 12 Old 08-02-2009, 05:53 AM
TurboBlew
Resleeves rnaz's borings
TurboBlew's Avatar
Vehicle: 1998 "wannabe" R/T
Modifications: Assembled at the dodge factory, caught fire 10/19/08
Quoted: 5 Post(s)
white smoke = coolant leak
The ALLIANCE is watching this post!!
TurboBlew is offline
post #3 of 12 Old 08-02-2009, 05:56 AM Thread Starter
UberFr0g
UberFr0g's Avatar
coolant leak as in....coolant in my oil?
forgot to mention my cat has been rattlein around for a couple of months and i just recently started getting an o2 sensor code...im assuming the rear one. but its not on anymore.
UberFr0g is offline
post #4 of 12 Old 08-02-2009, 05:58 AM
Rebel13
Mods Addict
Vehicle: 2K R/T
Coolant from heads.
Rebel13 is offline
post #5 of 12 Old 08-02-2009, 06:11 AM Thread Starter
UberFr0g
UberFr0g's Avatar
great.....fml
2 dodges.....both dead......
UberFr0g is offline
post #6 of 12 Old 08-02-2009, 07:27 PM
99Dakota
Diesel Mechanic
99Dakota's Avatar
Vehicle: 99 Dakota 4x4
sure it not just condensation? and your oil pressure at idle should be high when the engine is not up to temps idling. it should fall to half way point or lil under after warm up.
99 Dakota Sport 4x4 3.9L V6
360 Air Intakez, V8 TB, MSD Coil, Magnaflow Y-Pipe back, Superchips 3715, Factory 3.92's, Firestone Destination A/T's, HID 5000K BI, HID 6000k Fogs, Monroe Sensatrac Rear Loadlevelers
99Dakota is offline
post #7 of 12 Old 08-02-2009, 07:46 PM Thread Starter
UberFr0g
UberFr0g's Avatar
well, i went out today....actually has a little light cause it was daylight. The oil doesn't appear to be milky (checked before i started it and after it idled for a bit) and there does not appear to be oil in the overflow tank water.
I've never nopticed it idling at 3/4 like it does now. I recently did a full tune up on it. Had to change the oil because the truck had been neglected and not changed for over 7k....someone else was using it for a while .
It looks liek white smoke but could it be from the new oil breaking up some gunk left behind from the old and causing a clog/burning off??
The white smoke is hardly noticeable unless u look for it during the day...seems to be dripping a bit of condensation from the exhaust but nothing major.
I just do not want to drive it if it is a cracked head or blown gasket...i dont need that many problems right now with school starting back in 3 weeks
UberFr0g is offline
post #8 of 12 Old 08-02-2009, 07:55 PM
bwdakrt
Posts: n/a
Quoted: Post(s)
7K????????????? Damn, I hope you had synthenic oil in the crankcase!!
I think you may be getting all excited about a little condensation. Take it for a drive, let everything come up to operating temp and then get back with us.
post #9 of 12 Old 08-03-2009, 01:23 AM
Little Blue Guy
#19 ƃop ǝnןq ǝןʇʇıן
Little Blue Guy's Avatar
Quoted: 22 Post(s)
I agree...check all your fluids and take it for a nice easy drive...all engines make water out the tailpipe....and it just may have been "grayish" smoke you saw..which is normal
Little Blue Guy is offline
post #10 of 12 Old 08-04-2009, 08:05 PM Thread Starter
UberFr0g
UberFr0g's Avatar
Yes, fully synthetic every time. Changed the oil again....pretty darn sludgy, and took it for a spin to the mechanic. Shop did a few compression tests and whatnot and says everything appears to be fine. Its been raining alot here lately so it's most likely moisture.
Do have a massive exhaust leak though.
UberFr0g is offline
post #11 of 12 Old 08-04-2009, 09:47 PM
oreoacid
oreoacid's Avatar
Vehicle: 1998 Dakota Reg Cab
Send a message via AIM to oreoacid
do you go to tjc?
4/8 of a v8
SECOND. lifted 2wd 4 cyl gen III
hah.
oreoacid is offline
post #12 of 12 Old 08-06-2009, 04:31 AM Thread Starter
UberFr0g
UberFr0g's Avatar
Originally Posted by oreoacid View Post
do you go to tjc?
Nope, I go to UT Tyler about 2 whole miles down the road hahaha. I swear i spend more time on TJC's campus though.
UberFr0g is offline
