Brake dragging questio - Dakota Durango Forum
post #1 of 12 Old 07-31-2009, 04:29 PM Thread Starter
centex_R/T
Super McCool Dude
centex_R/T's Avatar
Vehicle: 2000 cc Dakota R/T
After a recent brake job, I have a problem with the brakes dragging and the wheels and rotors getting extremely hot. I was about to replace the calipers but wanted to check for a cheaper solution first. I just find it hard to believe that both calipers would go bad at the same time.
Everything went back together fine. If I jack of the front end, both wheels spin for a second and then stop, like there is just a slight drag, but enough to cause excessive heat.
As a driver I hate pedestrians, and as a pedestrian I hate drivers, but no matter what the mode of transportation, I always hate cyclists.
centex_R/T is offline
post #2 of 12 Old 07-31-2009, 04:45 PM
ramayer
ramayer's Avatar
Vehicle: 1999 durango (5.2L)
may need flex lines, they tend to break down and put crap into calipers causing them to stick.
I had both calipers replaced within 3-4 months, didn't replace flex lines and they are draging again. trying to find stainless flex lines for '99 ('00 up are different I guess)
mods: Functional ram air hood, 17" rt rims, 3" Magnaflow cat back, Eddy shorty headers,JBA y-pipe, RHS indy heads, 1.6 RR, comp cam .480 lift, MP valve springs, Comp cams double roller timing set, modified kegger intake, TB by Dwight, Grille craft inserts, Infinity Reference speakers all around with 10" Infinity sub in custom fibreglass enclosure, flip down DVD.
ramayer is offline
post #3 of 12 Old 07-31-2009, 05:32 PM Thread Starter
centex_R/T
Super McCool Dude
centex_R/T's Avatar
Did both start dragging at the same time?
post #4 of 12 Old 07-31-2009, 05:34 PM
GWhaley
Vehicle: 2001 Dakota Q.C.
Did you clean up and lube the sliders?
GWhaley is offline
post #5 of 12 Old 07-31-2009, 05:39 PM Thread Starter
centex_R/T
Super McCool Dude
centex_R/T's Avatar
Yea, the sliders were removed, cleaned, and lubed with fresh grease.
Do new pads normally come with replacement anti-rattle clips? Mine were off the truck for a long time and I put them back on when I did the brake job.
post #6 of 12 Old 07-31-2009, 05:40 PM
ramayer
ramayer's Avatar
when they origionally hung up it was 3-4 month apart. but now they both seem to be dragging a little (not enough to create much heat but more so than when first installed)
ramayer is offline
post #7 of 12 Old 07-31-2009, 05:41 PM
ramayer
ramayer's Avatar
what did you use? no antisieze are chassis grease, should be a brake lube od dielectric grease.
ramayer is offline
post #8 of 12 Old 07-31-2009, 05:43 PM
GWhaley
I just did a brake job last week, and I had cleaned up the sliders, etc. and still had one that hung up - I ended up changing it. It is possible that both need replaced - if you do decide to replace it make sure you call a lot of different suppliers - the price of these seem to change at every store.....
GWhaley is offline
post #9 of 12 Old 07-31-2009, 05:57 PM Thread Starter
centex_R/T
Super McCool Dude
centex_R/T's Avatar
It was the lube that came with the pads. It was clear like dielectric grease.
post #10 of 12 Old 08-01-2009, 06:51 AM
caulk04
Vehicle: none
Flush your brake fluid out until you get clean fluid at the wheel cylinders and calipers, then replace your calipers and flex lines. Rebleed the system and all will be well. $5 says that fixes your problem.
No. Dielectric grease is NOT a suitable substance for brake contact points.
caulk04 is offline
post #11 of 12 Old 08-01-2009, 06:58 AM
mthandt
mthandt's Avatar
Vehicle: 2002 Dakota QC
Modifications: K&N 77 series,Superchips 3715.
Send a message via AIM to mthandt Send a message via Yahoo to mthandt
This is the stuff I use to grease my pins and what not for my brakes.
http://www.permatex.com/products/Aut...per_Lube_1.htm
They also have some new purple stuff out to. It is a little pricey but I will probably have the little container forever becasue I hardly have to use any of it and it never washes out.
My truck is cool.
mthandt is offline
post #12 of 12 Old 08-02-2009, 12:10 AM Thread Starter
centex_R/T
Super McCool Dude
centex_R/T's Avatar
Paypal is chris.tcmtx@gmail.com
Alright, I replaced the flex lines, calipers, rotors, greased the sliders, and flushed two large bottles of fluid through the system and the brakes are still hot enough to sizzle when sprayed after a short drive. The wheels will burn your hand if you leave it on them for a second.
Any other ideas?
