idle air control valve? - Dakota Durango Forum
post #1 of 13 Old 07-26-2009, 02:10 AM Thread Starter
catdaddy614
Fishing technician
catdaddy614's Avatar
Vehicle: 2004 Dodge Dakota
Quoted: 4 Post(s)
I have a rough idle and I want to take the idle air control valve off. I took the 1 torx screw off and I thought it would come off but it didnt. What do I need to take off to get the IAC valve off? This is a 2004 with a V8 4.7. Help please.
catdaddy614 is offline
post #2 of 13 Old 07-26-2009, 03:12 AM
flyboy121785
Vehicle: 2002 Durango SXT 4.7L
Theres 2 screws i think, take the whole TB off because you will want to clean it. The crank case gases reroute into the intake tube and into the tb. Lots of nice carbon buildup.
flyboy121785 is offline
post #3 of 13 Old 07-26-2009, 03:25 AM
mthandt
mthandt's Avatar
Vehicle: 2002 Dakota QC
Modifications: K&N 77 series,Superchips 3715.
Send a message via AIM to mthandt Send a message via Yahoo to mthandt
There is only one screw on his 04. I would think because of only having one screw it might twist in but I don't really think it does. I don't recall when I took the IAC sensor off an 03 TB that I sold. I think it should just come out, might just be stuck from the o-ring.
My truck is cool.
mthandt is offline
post #4 of 13 Old 07-26-2009, 03:46 AM Thread Starter
catdaddy614
Fishing technician
Quoted: 4 Post(s)
will it hurt the IAC valve if I try to tug it off hard? or should I not do that. I cleaned the throttle body and inside and out already. Just need to clean the IAC. but wont come off maybe I need to tug it off.
post #5 of 13 Old 07-26-2009, 03:52 AM
mthandt
mthandt's Avatar
I wouldn't really "tug" it off because it is a delicate sensor and if you hit or twist the plunger on it it can go bad. You could give it a little moderate force but be very careful not to hit it when you are trying to pull it out.
My truck is cool.
mthandt is offline
post #6 of 13 Old 07-26-2009, 03:54 AM
mthandt
mthandt's Avatar
Maybe try to wiggle it back and forth and see if it will loosen. Again I am not to familiar with the 2003+ IAC sensor and how it mounts to the TB.
My truck is cool.
mthandt is offline
post #7 of 13 Old 07-26-2009, 04:28 AM Thread Starter
catdaddy614
Fishing technician
Quoted: 4 Post(s)
im kinda scared to mess with it.. maybe someone with the same IAC valve can help?
post #8 of 13 Old 07-26-2009, 04:44 AM
mthandt
mthandt's Avatar
I'm sure someone with the right year truck will chime in soon. Sorry I couldn't be of more help to you though. I definitely do not recall having any difficulties when I was removing the sensor from the 03 TB that I acquired.
I'm sure yours is just gummed up and stuck but I would be the same way if I was in your situation, afraid to break something.
My truck is cool.
mthandt is offline
post #9 of 13 Old 07-27-2009, 12:59 PM
mlobitz
mlobitz's Avatar
Vehicle: 2002 Dodge Dakota QC
Modifications: 3" JBA CatBack Exhaust, SuperChips Programmer, K&N Drop In Filter, Airaid MIT Intake Tube, Tint, Tinted Taillights
IF you didn't get the IAC valve off than you haven't cleaned the TB "inside and out"... There is a large cavity where the IAC sits that will be VERY dirty.
mlobitz is offline
post #10 of 13 Old 07-27-2009, 08:05 PM
Jecht
Mods Addict
Jecht's Avatar
Vehicle: 03 Dakota QC
the IAC on an 03+ TB has a double O ring that is a real tight seal. you can try twisting it back and forth and it should break loose. Just be careful when putting the IAC back in. you can cut the o rign real easy as I have done. if you do cut one. just go to auto zone and they will have an O ring that will fit it. where I got mine as the dodge dealership dont sell the O rings separately. they sell it in a ring pack and cost like 50 bucks or might be more.
but it will come out its just as tight as screwing a virgin
Jecht is offline
post #11 of 13 Old 07-28-2009, 04:09 PM Thread Starter
catdaddy614
Fishing technician
Quoted: 4 Post(s)
alright thanks man. ohhh do I have to take the throttle body apart to do this or can I just unscrew that 1 torx screw and pull it out?
post #12 of 13 Old 08-09-2014, 04:34 AM
Tonkadodge
What was the end result -did you have to tug it off?
Tonkadodge is offline
post #13 of 13 Old 08-11-2014, 04:00 AM
redram2007
redram2007's Avatar
Vehicle: 2007 Dodge Ram 1500
I've removed mine several times... I just put a flat tip screwdriver between the TB and the IAC valve and gently pry.
HO Cams, Volant CAI, SCT(X3) Tuned by Flyin Ryan, Power Wire, JBA Shorty Headers, Magnaflow Y-Pipe, QTP E-Cutout, Magnaflow 14", Flex a lite 183 E-Fan, 180 T-Stat, 08 Intake Manifold, F&B 72MM TB, Mag-Hytech Tans Pan & Diff Cover, 1 Ton Trans Cooler, Motive 4.56, OEM LSD, BT Catch Can. Ready to install: NX Proton Plus Kit, NX GENX-2 ACC Kit, Killian's P&P Heads & Beehive Springs, Edge 3K TC.
redram2007 is offline
