HO Alternators. - Dakota Durango Forum
General Parts Inquiries Can't find it in any other category?
post #1 of 19 Old 07-16-2009, 05:00 PM Thread Starter
HiJackZX1
HiJackZX1's Avatar
Vehicle: 2003 Dodge Durango SLT
HO Alternators.
My truck has a car pc system and even with it not being fully installed, the alternator cant keep up. I need a beefier alternator, but I see that not many people make a HO Alt for the Dakota or the Durango. I myself have a 03 Durango SLT 4.7. I found one from a company called powerbastards, but I wonder if 220 AMPS is enough?
Here is the link to the ALT. http://powerbastards.com/proddetail....=Fitzall%2D220
Does anyone know of maybe a 300 AMP Alt that fits on the 4.7 Magnum V8?
My setup is going to be as followed:
2 Alpine PDX 4.100, 500 watts ea
1 Alpine PDX 1.600, 600 watts
7 Lilliput screens, 7 watts ea
1 Eonen 19 inch, 15 watts
1 Eonen 10.2 inch, 10 watts
1 Dual Core PC, 320 watts
6 Single Core PC, 250 watts per 2
All little devices come out to about 30 watts total,
So thats around 2,774 Watts the system may need..... can a 220 AMP ALT handle that?
CAR PC ITEMS [50%]
INSTALL OF PC [35%]
ENGINE MODS [0%]
HiJack ZX1 CAR PC Work Log
HiJackZX1 is offline
post #2 of 19 Old 07-16-2009, 05:35 PM
TurboBlew
Resleeves rnaz's borings
TurboBlew's Avatar
Vehicle: 1998 "wannabe" R/T
Modifications: Assembled at the dodge factory, caught fire 10/19/08
Quoted: 5 Post(s)
whats the amperage at idle? 220 amps at 3000 rpm does ya no good.
The ALLIANCE is watching this post!!
TurboBlew is offline
post #3 of 19 Old 07-16-2009, 06:26 PM
00bluedak
The Metal Doctor
00bluedak's Avatar
Vehicle: 2000 dakota quad cab
Modifications: alot
Send a message via Yahoo to 00bluedak
says it does 110 at idle and 220 at 1200 rpm
Project SIC SIX 2000 Dodge Dakota Quad Cab V6 Intense Blue Pearl. too many mods to list
Project GREEN MEANIE 1985 Jeep Cj7 Built 258ci I6 Too many mods to list
Project GUESS AGAIN 2000 Yamaha V Star 650 Classic
MADR/T MEMBER
00bluedak is offline
post #4 of 19 Old 07-16-2009, 07:00 PM
ColoDak
ColoDak's Avatar
Vehicle: '00 Dakota, '09 Kawi
Quoted: 2 Post(s)
you need to do some better searches, there have been other people looking for these and there are several out there
'00 Dak. Q-Cab, Intense Blue, 5.9 360, AWD
http://www.cardomain.com/ride/3183475/2
ColoDak is offline
post #5 of 19 Old 07-16-2009, 07:05 PM
TurboBlew
TurboBlew's Avatar
Quoted: 5 Post(s)
missed that part...der. Thats pretty good.
post #6 of 19 Old 07-16-2009, 08:37 PM
Jjud13
Jjud13's Avatar
Vehicle: 00 Dakota
Modifications: Custom intake, relocate IAT, dual exhaust, removed clutch fan
220 amps should be good enough for you. You'd be pullin around 230amps at 12 volts with all the stuff on your list runnin wide open.
Custom intake, V8 throttle body; relocate IAT, dual exhaust, removed clutch fan, 3" body lift w/ 33's, modded kegger
Jjud13 is offline
post #7 of 19 Old 07-16-2009, 09:08 PM Thread Starter
HiJackZX1
HiJackZX1's Avatar
Thanx for your help guys. I do not think it will all run wide open 100% so 220 should be good.
CAR PC ITEMS [50%]
INSTALL OF PC [35%]
ENGINE MODS [0%]
post #8 of 19 Old 07-16-2009, 09:24 PM
hskrRT
nstg8tr
hskrRT's Avatar
Vehicle: 2000 R/T
Modifications: Lots 'O stuff
Quoted: 190 Post(s)
It says 110 at idle, but what does it consider idle RPM, what size pulley is on the alternator compared to stock? might be bigger or smaller and actually throw off the numbers. Also some manufactures like to pad thier numbers to sell alternators. I had a 160amp "high output" alternator I bought off Ebay that was worse at idle than my stock alternator.
hskrRT is offline
post #9 of 19 Old 07-16-2009, 09:50 PM
FSTDANGO3
THE YETI
FSTDANGO3's Avatar
Vehicle: 2013 R/T D HEMI
Modifications: CUSTOM CARS
There are also a few out there that will push some power but create some alternator whine as well
2013 R/T D HEMI 6 SPEED AUTO AWD
FSTDANGO3 is offline
post #10 of 19 Old 07-17-2009, 01:08 PM
FSTDANGO3
THE YETI
FSTDANGO3's Avatar
Called that company yesterday they do not make a high output for the 4.7 Durangos
They only make a HO GM style 1 wire alternator that will require you leave the factory harness disconnected from the new alternator causing a Mil light to come on Also they stated that the mounting may require some modification
I have tried excessive amperage alternators 3 times and every time the alternator worked good but caused alternator whine.
Put on my stocker and noise was gone completely
Just recently got a new 160 stocker and ity makes no noise as well
post #11 of 19 Old 10-26-2009, 08:25 PM Thread Starter
HiJackZX1
HiJackZX1's Avatar
Don't know why I missed your post. I actually ended up buying the 220 amp, but it is so hard to get mounted, and the manufacturer doesn't even know the specs to his own product. This thing seems to be geared more towards imports and cars with small alternators that do not have the room. I will most likely go with the 160 that you suggested. I just hope its enough to power everything I have.
I am curious to know if anyone is running a large setup like mine and if the 136 or 160 can handle it easily.
PS: Is there a dual alternator bracket setup for the Durango? That would solve alot of issues!
CAR PC ITEMS [50%]
INSTALL OF PC [35%]
ENGINE MODS [0%]
post #12 of 19 Old 10-27-2009, 12:59 PM
FSTDANGO3
THE YETI
FSTDANGO3's Avatar
Get a new 160 and Run Dual Batteries
post #13 of 19 Old 10-27-2009, 01:55 PM Thread Starter
HiJackZX1
HiJackZX1's Avatar
Yea, but there is no challenge in that. Plus I have the 220 laying around. See, the 220 is basically bad at replacing the stock alternator, but adding it seems to be easy.
Now when adding it, should I worry about heat issues? How much space should I give this thing. I see that the engine bay looks less cluttered in the 5.9. My 4.7 is full of electronics and crap like that.
CAR PC ITEMS [50%]
INSTALL OF PC [35%]
ENGINE MODS [0%]
post #14 of 19 Old 12-17-2010, 11:24 PM
BobinCocoa
BobinCocoa's Avatar
Vehicle: 00 CC, 01 QC & 03 Durango
Modifications: 2000 CC - HO Cams, P&P Throttle Body, CAI, Dual Exhaust
So, did you mount it as a secondary alternator? I am looking for pics of a 2nd alt install in a 2000-2003 dakota or durango
BobinCocoa is offline
post #15 of 19 Old 12-19-2010, 02:47 AM Thread Starter
HiJackZX1
HiJackZX1's Avatar
In the end, I sold the 220 HO alt and am now saving up for a 260 amp from DC Power. It puts out 200 amps idle, which is enough for me. Then I think at 1500 rpm it puts out the full 260 amps. The way the engine is, its to hard to do a dual setup. It seems easier to do on the 5.2 and 5.9 engines.
CAR PC ITEMS [50%]
INSTALL OF PC [35%]
ENGINE MODS [0%]
