Can't take the clutch fan off - Dakota Durango Forum
Maintenance Forums Keep your truck looking and running its best with this advice.
post #1 of 21 Old 07-09-2009, 12:20 AM Thread Starter
EasyEDak3.9
EasyEDak3.9
EasyEDak3.9's Avatar
Vehicle: 2000 Dodge Dakota Sport
Modifications: K&N Filter...180* Thermostat
Send a message via AIM to EasyEDak3.9
Mine is bad. It's rattling and making tons of noise up front and its pissing me off ALOT.
I tried removing it though with a big ass wrench and it's not budging...the water pump pulley wants to spin.
I took off the upper fan shroud to get access to it better but thats not helping. Is there any way i can lock up the waterpump pulley so it doesn't spin...? I'm tempted to just take it to a shop for them to remove it.
Performance: 5.9 Swapped - Mopar DR TC - Dynomax Exhaust - Modded Keg - Dwight TB - Built 42re
Exterior: Moore Performance SRT10 Hood - Stillen Bumper - Depo Euro HL - Graphite R/T Wheels - OEM Flares - 20/5% Tint - 5000K HID
Interior: Durango SLT Leather Buckets + Center Console - Kenwood Audio - Passport 8500
EasyEDak3.9 is offline
post #2 of 21 Old 07-09-2009, 01:47 AM
6115
place lock jaw pliers on waterpump pully
use a wrench to bust fan off (lefty loosey righty tighty)
6115 is offline
post #3 of 21 Old 07-09-2009, 01:49 AM
TurboBlew
Resleeves rnaz's borings
TurboBlew's Avatar
Vehicle: 1998 "wannabe" R/T
Modifications: Assembled at the dodge factory, caught fire 10/19/08
Quoted: 5 Post(s)
no wonder your name starts with easy! you give up real easy!
The ALLIANCE is watching this post!!
TurboBlew is offline
post #4 of 21 Old 07-09-2009, 02:11 AM
Little Blue Guy
#19 ƃop ǝnןq ǝןʇʇıן
Little Blue Guy's Avatar
Quoted: 22 Post(s)
There is a special water pump pulley holder that has pins on it that go into the pulley holes.....you can try to put a phillips screwdriver in there and lock it against the pump, or a punch will work as well.....or, if you have an air hammer and a pointed bit, you can lightly hammer the nut off the water pump by putting the pointed bit on the left side of the large nut and give trigger a pull...once you get it loose, it will spin right off.....careful with the vise grip on the pulley, the pulley is not all that hard...bends easily
You sure it's the fan clutch making noise and not the water pump itself??
Little Blue Guy is offline
post #5 of 21 Old 07-09-2009, 02:22 AM
trevor
Vehicle: Null
Oh wow, so much for "using the right tool for the job" eh? I guess they are called water pump pliers
As said before, vice grips could wreck the pully. I'm not sure about 2000's, but that pully is part of the water pump on my 99, bugger it, and replace the water pump.
There is a proper tool to fit into 2 of the 4 (I believe) holes that are in the pully. If you're crafty, you can make a tool. Thats what my dad and I did.
Get the proper sized wrench (I dont remember what size it is) and give the nut a turn. Once you break it loose, it will spin off real easy.
A good sharp edge is a man's best hedge against the vague uncertainties of life.
trevor is offline
post #6 of 21 Old 07-09-2009, 02:24 AM
hskrRT
nstg8tr
hskrRT's Avatar
Vehicle: 2000 R/T
Modifications: Lots 'O stuff
Quoted: 190 Post(s)
Either way he needs to remove the clutch fan to replace it. If you have the big ass wrench to fit the nut, put it on. Leave the belt on, and if you have an extra set of hands, somebody else with a 15mm wrench who can put extra pressure on the tensioner pulley will help hold the waterpump. Then use a Ford wrench(BFH--big fucking hammer) and hit the wrench on the nut towards the passenger side. Quick sharp blow should jar it loose, and once it's broke loose it wil spin right off. be carefull not to let the fan fall into the radiator and damage the fins on the radiator.
hskrRT is offline
post #7 of 21 Old 07-09-2009, 02:25 AM
hskrRT
nstg8tr
hskrRT's Avatar
Vehicle: 2000 R/T
Quoted: 190 Post(s)
Or buy you some strap wrenches to hold the pulley with.
hskrRT is offline
post #8 of 21 Old 07-09-2009, 03:00 AM
6115
I have used the locking pliers method for a long time on many vehicles (04 dodge ram (4.7), 98 Mitsubishi montero (3.0), and my dak with no damage to the pulley, and I have never bent a pulley in the past (I have the old 4.7 water pump in my lap right now and can spin the pulley, it is straight and true and I have done this over 10+ times on this water pump alone) , I wouldn't hesitate to use this method to take the fan off at all. Like mentioned there are many tools you can use for the job some better then the others but if you don't have to make/rent or buy expensive "right" tools to serve the same purpose, why not?
only situation I couldn't use the locking pliers method was when I had to replace a radiator on my dads 2001 BMW 530I, we had to buy a special $50 BMW pulley holder.
6115 is offline
post #9 of 21 Old 07-09-2009, 03:11 AM
Little Blue Guy
#19 ƃop ǝnןq ǝןʇʇıן
Quoted: 22 Post(s)
The water pump pulley holder for the Dodges is cheaper than that....
post #10 of 21 Old 07-09-2009, 04:29 AM
hskrRT
nstg8tr
hskrRT's Avatar
Vehicle: 2000 R/T
Quoted: 190 Post(s)
Strap wrenches aren't expensive either and come in handy for a lot of different things.
hskrRT is offline
post #11 of 21 Old 07-09-2009, 04:58 AM
trevor
Vehicle: Null
Yeah, I agree, some of these are a bitch.
The clutch fan on my 5.2 that i put in was on the water pump good and tight. We had lots of room to work, because it was sitting on an engine stand. As a last resort we decided to use the fire wrench (oxyacetylene torch). We heated up the nut slightly and put a wrench on it and hit it with a hammer...no luck. We decided to leave it for the night, and work on it the next morning. The next morning my dad asked how we got the clutch fan off. We said we didnt, but he went out earlier in the morning, and just spun it off by hand.
trevor is offline
post #12 of 21 Old 07-09-2009, 05:16 AM
SCredneck
SCredneck's Avatar
Vehicle: 99 Durango SLT 4x2 5.9
Had the same problem last weekend. Fan clutch and water pump went. Could NOT get the clutch off. Bent the heck outa the pulley, and broke the handle on one strap wrench. then sd screw it and install a e-fan and saved $50.
99 Durango SLT 4x2 5.9 (wife's ride)
76 Charger SE work in progress (father-son project)
SCredneck is offline
post #13 of 21 Old 07-09-2009, 05:19 AM
Hahns5.2
No Boost? Why Drive?
Hahns5.2's Avatar
Vehicle: 95 Dakota Sport
Whats always worked for me is to place the wrench on it and give it a whack with a hammer, they usually bust free after a few whacks.
5.2, 5 Speed, MS3X (Full Sequential, Spark, Idle, Boost Control, Fan, Water/Meth), HX40 Pro/P-Trim Hybrid.
Hahns5.2 is offline
post #14 of 21 Old 07-10-2009, 07:16 PM
Mesa R/T
Vehicle: 2002 Durango R/T
Modifications: Axed the Airbox and made my own
Send a message via Yahoo to Mesa R/T
I used a piece of wire rope (aircraft cable) and ran it through one of the holes in the pully, wrapped it around the tensioner arm and tied it. I didn't have a wrench the right size for the nut so I used the air happer trick. there were already marks on the nut from the previous replacement.
Mesa R/T is offline
post #15 of 21 Old 07-11-2009, 02:25 AM
Little Blue Guy
#19 ƃop ǝnןq ǝןʇʇıן
Quoted: 22 Post(s)
Good idea...didn't think of the wire trick....
