Factory HU and amp wire colors - Dakota Durango Forum
Audio, Security & Multimedia Speakers, Amplifiers, Subwoofers, Alarms, TV's, Game Consoles
Thread Tools Rating: Thread Rating: 36 votes, 5.00 average. Display Modes
post #1 of 14 Old 07-08-2009, 03:47 PM Thread Starter
ThisOldDak
Vehicle: 2010 Nitro SXT
It took a ton of searching, but I found the wire color chart/pinout for both head unit and the amp output for 97 (through 99?) factory infinity systems. Figured others might find it usefull... Maybe have a sticky for stock wiring info? I'll post it up when I get home this evening.
ThisOldDak is offline
post #2 of 14 Old 07-11-2009, 06:24 AM Thread Starter
ThisOldDak
The external Infinity amplifier is mounted behind the passenger side kick panel. It has (2) connector's. In this text they are labeled C1 which is the 14 pin connector, and C2 which is the 10 pin connector, as they are labeled in the dodge service manual drawings. "Right" is the passenger side.
Connections at the amplifier:
C1 (Amplifier Power, Ground, and Outputs to the Speakers):
C1-1 DG/WT <--- Fuse Panel - C6-3 Fuse 4, 15A
C1-2 DG/WT <--- Fuse Panel - C6-3 Fuse 4, 15A
C1-3 No Connection
C1-4 LG/VT ---> Left Front +
C1-5 TN/VT ---> Right Rear +
C1-6 WT/RD ---> Left Rear +
C1-7 <---> Ground
C1-8 <---> Ground
C1-9 No Connection
C1-10 LB/DG ---> Right Front --
C1-11 LB/RD ---> Right Front +
C1-12 LG/DG ---> Left Front --
C1-13 TN/DG ---> Right Rear --
C1-14 WT/BK ---> Left Rear --
C2 (Amplifier Remote On/Off, Speaker Line Inputs from HU):
C2-1 BR/RD <--- Left Front --
C2-2 DB/RD <--- Right Front --
C2-3 DB/OR <--- Right Rear --
C2-4 DG/RD <--- Remote Amp On/Off
C2-5 DG <--- Left Front +
C2-6 VT <--- Right Front +
C2-7 BR/YL <--- Left Rear +
C2-8 BR/LB <--- Left Rear --
C2-9 DB/WT <--- Right Rear +
C2-10 No Connection
Speaker Connections, (at the speaker):
RightFront + <--> LB/RD
RightFront -- <--> LB/BK
RightFrontTweeter + <---> LB/RD
RightFrontTweerer -- <---> LB/BK
LeftFront + <---> LG/VT
LeftFront -- <---> LG/DG
LeftFrontTweeter + <---> LG/VT
LeftFrontTweeter -- <---> LG/DG
RightRear + <---> DB/WT
RightRear -- <---> DB/OR
LeftRear + <---> BR/YL
LeftRear -- <---> BR/LB
Legend:
C#-# Connector and pin number.
<---> Connector
<--- Input
---> Output
+ Positive
-- Negative
Color Codes:
WT = White
BK = Black
BR = Brown
DB = DarkBlue
RD = Red
OR = Orange
DG = DarkGreen
VT = Violet
YL = Yellow
LB = LightBlue
I pulled this off another forum I had to dig through. That was a while ago and I can't seem to find it again to give credit. The guy did mention he was colorblind but 95% of the colors are correct, and the others are close enough that you can't realy confuse it with another wire. IE one marked red might realy be more violet.
post #3 of 14 Old 07-11-2009, 05:56 PM
IowaSQ
IowaSQ's Avatar
Vehicle: 2000 CC SLT
FYI(since you're a bit new to the site)....the entire factory service manual is posted on this site somewhere in .pdf.....it contains every connection/pin/wire color/etc for the entire truck.
IowaSQ is offline
post #4 of 14 Old 07-13-2009, 02:50 PM Thread Starter
ThisOldDak
I don't want to sound like I'm attacking or anything but,
"somewhere" isn't very helpful. I've now looked through the forums I'd think it would be in, and used the search tool. Sofar nothing.
It's useless unless it can be easily found. That's why I'm a fan of having stickys with all this basic info.
post #5 of 14 Old 07-13-2009, 03:15 PM
Boomin5POINT9
I bleev u have mai staplr
Boomin5POINT9's Avatar
Vehicle: 1999 Dodge Dakota R/T
Modifications: Automobile Customization, Mobile Electronics
Send a message via AIM to Boomin5POINT9 Send a message via Yahoo to Boomin5POINT9
I couldn't find it on this site either. And that stupid 15 second wait between searches soon ended my indeavor. I found one online for a 2000, 2001, and 2004, but nothing for 97-99 yet.
- Troy
1999 RC Dakota R/T:
Kenne Bell Supercharger, Alchohol Injection, SCT Pro-Racer Package, 50# CPR Injectors, Walbro 255LPH Fuel Pump, Ported 50mm TB, JBA Shorty Headers, Flowmaster 40, 3-Inch Exhaust, MOPAR M1 Manifold, Street Scene Mirrors, 20" Chrome XS Rims, GY HP Ultra Plus's, DynoJet Wideband, MSD 6A, MSD Coil, Hotchkis TVS, Bilstein shocks, Cervini's S.S. Ram-Air Hood, Sir-Michael's Roll Pan, Stillen Front Bumper, Diamond Headlights/Corners, Custom Leather Door Panel pads, 180 Degree T-Stat, Taylor Wires, Optima Yellow Top, and More.
Boomin5POINT9 is offline
post #6 of 14 Old 07-13-2009, 05:11 PM Thread Starter
ThisOldDak
It's give and take. if they didn't put a time cap on it, the server would get nuked with search requests. 15 second's is pretty low compared to other forums I've been on.
post #7 of 14 Old 07-13-2009, 08:38 PM
IowaSQ
IowaSQ's Avatar
http://www.dakota-durango.com/forum/...ad.php?t=39972
i got lucky on that one...it's stickied in the troubleshooting section....the 97-99 should be pretty similar to the 2000 other than a couple of minor points on the front suspension and a complete lack of info on 5.2 motors.
IowaSQ is offline
post #8 of 14 Old 08-23-2009, 03:31 AM
Abkshelby
Abkshelby
Abkshelby's Avatar
Vehicle: '99 Dakota R/T CC
Modifications: None. Stock.
Send a message via AIM to Abkshelby Send a message via Yahoo to Abkshelby
This will come in handy. My amplifier was removed from my truck and I need to find another one and the wiring connectors. Trying to revert back to the stock infinity system.
Alan Keithley
Newport News, VA
'99 Dakota R/T CC (Deep Amethyst 139k)
'99 Durango SLT (157k)
And a yard full of turbo Mopars
Abkshelby is offline
post #9 of 14 Old 08-28-2009, 03:14 PM
Mezz2006
Vehicle: 2000 Dodge Dakota CC
Modifications: Clutch Fan Delete and soon to have a new sound system
I wish I would have found this sooner, I spent 2 hrs figuring wires out in order to bypass the amp.
Abkshelby - I can sell you mine. I don't plan on putting it back in ever. Let me know if you are interested.
Mezz2006 is offline
post #10 of 14 Old 08-31-2009, 07:27 PM Thread Starter
ThisOldDak
I believe the radio is a different unit, but have no idea of the wiring.
Either your truck's got balls or it doesn't. No fake plastic scrotum necessary.
Now dakotaless
post #11 of 14 Old 09-01-2009, 04:35 PM
Mezz2006
I'm pretty sure the radio's are the same from 1997 (or possibly earlier) to 2000. In 2001 is when they did the interior redesign, so at that point they changed the radios in the Dakota and Durango.
Mezz2006 is offline
post #12 of 14 Old 09-02-2009, 03:27 PM
Fltlander
Fltlander's Avatar
Vehicle: '01 QC SLT 4x4,'01 CC R/T
Modifications: '01 R/T:Rebuilt Frontend(Lowered),K&N '01 QC:Lowered,New Rubber,True Duels,Engine:Still Stock
Send a message via Yahoo to Fltlander
I know it's not free but this is a lot easier to bypass the amp...
http://www.dakota-durango.com/forum/...ad.php?t=68000
Jeff
Fltlander is offline
post #13 of 14 Old 09-02-2009, 04:00 PM Thread Starter
ThisOldDak
wow $30 is a little steep. but I was looking for something exactly like that for quite some time since I was having so much difficulty finding the pinout. I couldn't believe the other "bypass" kits just gave you a bunch of wire to go directly from the HU to the speakers.
in the end I found this info and cut n soldered the wires myself.
...all Info I find lists 97-99 and 00-04 as different setups. maybe there was a mid year change or something.
Now dakotaless
post #14 of 14 Old 07-14-2016, 11:19 PM
Dakota2001Dodge
Unhappy In Dire need
do u have an amp whats the part number mine is 56043050AF I need one with the connectors still in amp and wires cut about 3 inches back from connectors
Dakota2001Dodge is offline
