Oil Pressure Fluctuating - Dakota Durango Forum
2.5L/3.7L/3.9L Engines Questions regarding the I4 and V6 Engines
post #1 of 8 Old 08-11-2005, 06:23 AM Thread Starter
slvdak
Fuel Monster
slvdak's Avatar
Vehicle: 2002 Dodge Dakota
OK guys and gals,
I have a '02 Dakota 3.9 (65,000 km)and my oil pressure is up and down
I know that when your on the gas, it raises a little but this is up to the the line before the max out line and when your off the gas is drops back down.
At about 1000 rpm is seems fine.
I checked the oil and it's fine, it was changed less then a month ago.
Hopefully someone can shed some light on my problem
Thanks
Mark
Sydney, Nova Scotia
2002 Silver CC Dakota Sport
(under development)
Club Crew
slvdak is offline
post #2 of 8 Old 04-17-2007, 10:06 AM
bpitz15
bpitz15's Avatar
Vehicle: 2000 Dakota R/T
hahahaha im bringing back the dead but is this the oil sending unit going out?
Do you serve a purpose? or purposely serve??
Member #103
bpitz15 is offline
post #3 of 8 Old 04-17-2007, 02:38 PM
01SilverDak01
234 RWHP and 296 RWTQ!
01SilverDak01's Avatar
Vehicle: 01 Dakota CC 5.9 R/T
Typical Rule thumb on Oil pressure is you need 10 PSI for every 1000 RPM, as long as the the gauge is reading in the Nominal Sweep Range you should be ok.
also depending on the Oil Filter you used it could also be part of the issue if it drops excessively...
The Mopar, WIX / NAPA Gold, and Mobil-1 filters all have anti-drainback valves
to keep the oil in the filter and the pressure where it needs to be..
and yes the Oil pressure switch could be ready to crap out too..
Ron
15' Challenger SXT 3.6, Super Track Pak
01' Dakota SVR CC 5.9 R/T
1 of 529 built for 2001
01SilverDak01 is offline
post #4 of 8 Old 04-17-2007, 05:14 PM Thread Starter
slvdak
Fuel Monster
slvdak's Avatar
way back from the dead...
the oil sending unit was changed in august 2005, went retarded again, they changed it under warranty in july 2006. But nothing seemed to be wrong with the sending unit.
My oil was changed every 3 months, I'm under my mileage warranty. So I switched to Synthetic oil and installed an auto meter gauge.
The pressure is perfect, my in dash gauge is unplugged and it still moves a little bit, I have a cotter pin in it to shut the "check gauges" light off, on the dash.
So, it's basically electrical, where most ppl jump to the "sludge" factor.
But my oil pressure is fine now, and the gauge on the pillar with a blue LED looks pretty sweet, IMO hahahaha
Mark
Sydney, Nova Scotia
(under development)
Club Crew
slvdak is offline
post #5 of 8 Old 04-17-2007, 05:18 PM
bpitz15
bpitz15's Avatar
well i just changed my oil about 3 weeks ago also, and i used a fram oil filter. so maybe that was it. Its not a huge deal i just sit at around 30 psi at idle and go up to about 60 when accelerating
Member #103
bpitz15 is offline
post #6 of 8 Old 04-17-2007, 06:56 PM
SteveBDAK
My 97 Dakota has been doing that for about 5 years now... and I have 212K on it.
SteveBDAK is offline
post #7 of 8 Old 04-17-2007, 08:12 PM Thread Starter
slvdak
Fuel Monster
slvdak's Avatar
ya, that's about right man
give or take a few psi
mine was up and down all over the place quickly
now it's fine
70-75ish on start up, idle like 25-30ish, running normal (give or take on rpm) 50-60ish, to the floor 70-75ish
so, you should be ok; just keep an eye on it
Mark
Sydney, Nova Scotia
(under development)
Club Crew
slvdak is offline
post #8 of 8 Old 04-17-2007, 10:09 PM
theguitardoctor
Vehicle: 1998 Dodge Dakota Sport 2.5L 5 Spd manual
Thats exactly how the pump works...higher rpm equals more pressure needed from the pump, so oil pressure increases...at idle the pressure drops as the rpm's drop...it's normal...panic if it drops to zero...but you'll get warning lights by then...
theguitardoctor is offline
