Rear brake lock up - Dakota Durango Forum
post #1 of 5 Old 01-17-2004, 05:04 PM
Bill
Posts: n/a
Quoted: Post(s)
Question Rear brake lock up
My 2002 Quad Cab does not have 4 wheel ABS, but when I make sudden stops the rear wheels lock up and skid, is there an adjustment to stop this?
post #2 of 5 Old 04-09-2006, 12:28 AM
jkennedy620
Search and Rescue
Vehicle: 2004 DAKOTA 4X4 QUAD CAB
I had the same problem 02 dakota 2wd reg cab.. the mechanic changed the brake module, pad and machined the rotors problem solved
jkennedy620 is offline
post #3 of 5 Old 06-03-2006, 10:02 PM
Shatto
Shatto's Avatar
Vehicle: 98 3.9 auto, Dakota
Safety Issue. Ask Dodge if warranty, regardless of mileage, covers it.
You should almost never be able to lock up the rear brakes.
Shatto is offline
post #4 of 5 Old 06-05-2006, 01:28 AM
JP2002LS1
Vehicle: 1997 Dakota, 4X4, 5.2, 5 speed
Do you have rear disc brakes or drums? Is one tire locking up or both? If one tire is locking up then it is probably one of three things:
1. your parking brake is stuck on one side (doubtful)
2. something broke on one side rear (could be a spring if they are drum brakes), this could cause more pressure to go to the other side and lockup the brakes.
3. bad wheel cylinder (drum) or caliper (disc) on one side
I'm new to dakotas so I don't know what style rear brakes you have, but something is worn or broke if you are locking the rear brakes. The only other reason why your rear brakes would lock up is if your front brakes weren't working.
JP2002LS1 is offline
post #5 of 5 Old 06-05-2006, 02:03 AM
SmokinCummins
Vehicle: 98 Dodge Durango
An axle seal leaking oil into the brakes will make them grabby too.
Y2K Ram 2500 Cummins/Auto
640 horsepower and 400,000 miles
1998 Durango 360, 46RE, NP241DLD, D60s
2001 Ram 2500 Cummins/NV5600,241DHD - Sledpuller
SmokinCummins is offline
