2000 Durango Starter won't engage - Dakota Durango Forum
post #1 of 9 Old 06-02-2009, 12:14 AM Thread Starter
Jasonb61
Vehicle: -
Send a message via MSN to Jasonb61
Ok, so some may know I was chasing a problem with the 2000 Durango where the security wouldn't deactivate. Anyways, I believe that issue is resolved. However, now the starter won't engage. It will if I run a jumper across the relay but not from the key. I've checked fuses and swapped all relays around. Any ideas? It happened while I was running a jumper on the starter relay (I was under the hood and didn't have a second person to help me )
Everything else works from the ignition key such a fuel pump priming up, etc. Any ideas? Did I miss a fuse/relay?
Thanks
Jasonb61 is offline
post #2 of 9 Old 06-02-2009, 01:07 AM Thread Starter
Jasonb61
Vehicle: -
Not sure if it's related or not but I get the 'ABS' and 'BRAKE' light when I try to turn the engine over with the key.
Jasonb61 is offline
post #3 of 9 Old 06-03-2009, 01:47 AM Thread Starter
Jasonb61
Vehicle: -
Any ideas? Durango is sold if I can get this issue fixed lol
Jasonb61 is offline
post #4 of 9 Old 06-03-2009, 03:22 AM
Trouble Maker
Trouble Maker's Avatar
Vehicle: 02 & 03 Dakota Quad Cabs
Check your Neutral Safety Switch(NSS) wiring on the transmission.
Also, with the key held in the start position move the shifter out of park and through neutral to see if it is maybe just the linkage needs adjusting.
Russ
His-SASed 02 Dakota Quad Cab Sport 4x4 4.7 NV3500 5spd/Std D44/9.25" 4.88s lockers frt/rr 35" ProComp Extreme MTs frt EPi 9k Superwinch rear LP 8.5k Superwinch
Also his: 09 Power Wagon Hemi 4.56 gears 285/70R17 Duratracs factory winch and lockers
Hers-03 Dakota Quad Cab Sport 4x4 4.7 545RFE 5spd/Auto 3.92 L/S 265/75R16 Dueler RVTs 5th wheel hitch
Trouble Maker is offline
post #5 of 9 Old 06-25-2009, 10:24 PM Thread Starter
Jasonb61
Vehicle: -
Still no go... Any other ideas? I have this thing sold if I can get this fixed.
Jasonb61 is offline
post #6 of 9 Old 06-25-2009, 10:24 PM Thread Starter
Jasonb61
Vehicle: -
Where can I find the NSS wiring info?
Jasonb61 is offline
post #7 of 9 Old 06-27-2009, 12:07 AM
endgame
That's dag, yo.
endgame's Avatar
Vehicle: 1997 Dodge Dakota
Your situation is so similar to mine, it's almost funny. We're going to take a look at the starter today. I'm almost positive that's it or it's a connection going to the starter. I get the same thing with the abs and brake lights, as well.
endgame is offline
post #8 of 9 Old 06-30-2009, 02:29 AM Thread Starter
Jasonb61
Vehicle: -
well, I can still engage the starter from the power distribution box but not from the key itself..
Jasonb61 is offline
post #9 of 9 Old 06-30-2009, 02:29 PM
2K R/T
2K R/T's Avatar
Vehicle: 2000 Dodge Durango R/T
Install a Starter switch on the dash,Run wire to what will engage,Say it was your cheap "Viper Mod" starter button,Fixed and SOLD
Rick
2K R/T January 2008 TOTM
2000 5.9 R/T DURANGO 2008 AVENGER SXT 2006 HARLEY DAVIDSON STREET ROD
Mobile Audio World.com TOTW September 14 2003
Dodge Truck World.com TOTW September 21 2003
Suv World.com TOTW May 23 2004
Dakota-Durango.com TOTM July 2004
Durango Club.com DOTM March 2005
Cardomain.com Show off of The Week July 18 2005
Dodgetalk.com SOTM January 2007
Gimme Fuel,Gimme Fire,Gimme That Which I Desire
2K R/T is offline
