99 Durango 4x4 crossmember removal ? - Dakota Durango Forum
post #1 of 6 Old 05-31-2009, 03:55 AM Thread Starter
slodakota
Vehicle: 1997 Dodge Dakota
Transplanting the drivetrain from a rolled 99 Durango in to my 97 Dakota and today I removed the engine from the durango and am trying to remove the transmission but cannot get the transmission crossmember out. All eight bolts have been removed, transmission unbolted and lifted off the crossmember and I've even jacked up on the crossmember slightly. The crossmember will move slightly but cannot get it to move more than 1/4" in any direction. Any help would be greatly appreciated. Thanks!
slodakota is offline
post #2 of 6 Old 05-31-2009, 08:37 AM
muddigger4x4
MUDDIGGER
muddigger4x4's Avatar
Vehicle: 1999 Dodge Durango 5.9L
Modifications: opened exhaust slightly future change coming
Send a message via Yahoo to muddigger4x4
if its coming out of a rolled vehicle, torch the frame out around it, should pop right out then
RIP 5.9L Magnum
5 door whore #155
muddigger4x4 is offline
post #3 of 6 Old 05-31-2009, 01:18 PM Thread Starter
slodakota
That is my next option but wanted to learn the trick to removing it so when the motor & transmission come out of the dakota, I could put the information to use. The frame of the durango wasn't damaged when rolled just the top of the body. Thanks.
post #4 of 6 Old 06-01-2009, 03:00 AM
muddigger4x4
MUDDIGGER
ahh ok, good luck, im sure someone on here will know the answers
RIP 5.9L Magnum
5 door whore #155
post #5 of 6 Old 06-07-2009, 02:58 AM Thread Starter
slodakota
Finally took time to work on the durango today. I will post this for the sake of others who may be about to remove their transmission. If anyone has an easier way to accomplish the task or if the post needs corrections/additions, please feel free to add your input.
Removing the transmission required removal of the transfer case first including unbolting the shifter assembly and removal of both drive shafts. The transfer case is held in place by six (6) nuts which required a 14mm socket/wrench. The vent tube will need to be disconnected and then you can slide the transfer case back and out of the way.
The transmission needs to be unbolted from the crossmember and motor if not removing with the motor. Disconnect the wiring from the transmission and I removed the exhaust from the muffler forward for more room during transmission removal. The transmission now needs to be jacked up to clear the crossmember. I removed all eight bolts from the crossmember to frame connection and was then able to tap each side of the crossmember toward the back of the truck until it cleared the transmission. The transmission could then be lowered and removed.
My manual didn't spell this procedure out so I hope it helps save someone some time/trouble.
post #6 of 6 Old 06-08-2009, 03:32 PM
jimthedman
jimthedman
jimthedman's Avatar
Vehicle: 99 durango
Modifications: working on my d
thanks
jimthedman is offline
