Front brakes dragging - Dakota Durango Forum
post #1 of 28 Old 05-04-2009, 06:34 AM Thread Starter
Mas
Vehicle: '01 Dakota SLT 4 X 4
2001 Dak 4.7 4x4 SLT: I smoked my front driver's side brake with short city driving. It heated up to the point that I could smell it and pulled very hard to the left. This happened to me a year ago, but that time both fronts smoked! I let them cool, and they were fine since.
The previous owner also had brake issues and the dealer replaced rotors, calipers, and pads...seems to be another issue to be happening. Obviously the calipers are not releasing. Would the booster cause this problem?
MAS
Mas is offline
post #2 of 28 Old 05-04-2009, 07:38 PM
jskull360
jskull360's Avatar
Vehicle: 08 1500 hemi 4x4
i had that prob also on my 98 RT. I just decided to get the 04 dak brakes and hopfully that gremlin doesnt come back. I also replaced the booster before i did the swap and it made it worse,driverside never fully released, also replaced rubber brake lines
jskull360 is offline
post #3 of 28 Old 05-05-2009, 12:45 PM
mlobitz
mlobitz's Avatar
Vehicle: 2002 Dodge Dakota QC
Modifications: 3" JBA CatBack Exhaust, SuperChips Programmer, K&N Drop In Filter, Airaid MIT Intake Tube, Tint, Tinted Taillights
This seems to be fairly common with these trucks. I would replace the calipers at a minimum, but if it has happened more than once you may want to replace the soft lines as well...
mlobitz is offline
post #4 of 28 Old 05-05-2009, 01:13 PM
BOOM_FIST
The Asian Persuasion
BOOM_FIST's Avatar
Vehicle: 2002 QC 4x4 4.7
Modifications: 3" BL, P&P TB, CAI intake, 33x12.5 Swampers
Ya ain't shittin man....this exact same shit happened to me....front drivers brakes were smoking. I spent over $700 and replaced both calipers, pads, brake lines, and upgraded to Brembo cross drilled rotors and they still have fucking problems! Don't get me wrong, the brembos help out a lot along with the pads...they bite hard, but they just don't feel right to me...it feels loose and lazy sometimes when I come to a stop...like the brakes catch late, then it all of a sudden jerks to a stop. Not to mention every set of rotors I've had on this truck have glazed over within fucking weeks of me having them...then along with the glazing comes the screeching of the brakes. I've had this truck in the shop for diagnosis over 12 times within the past 6 months...and that's not exagerating.
We should all get a petition going to chrysler about these crap brakes on our trucks......LOL....like they're going to do anything!!!!
"IF YOU DON'T STAND BEHIND OUR TROOPS, PLEASE FEEL FREE TO STAND IN FRONT OF THEM."
I MISS MY RIG.....
BOOM_FIST is offline
post #5 of 28 Old 05-05-2009, 01:25 PM
caulk04
Vehicle: none
Replace the lines and calipers. Problem solved. Very common.
caulk04 is offline
post #6 of 28 Old 05-05-2009, 02:49 PM
dualdakota02
dualdakota02's Avatar
Vehicle: 2002 dak QC 4x4, 4.7 v8
i think u mean flex lines only right... no need to replace steel lines right?
i had the same issue tho just recently. its been almost a month now since i swapped out the calipers, pads, rotors and flex lines on both front. bled fronts out. havn't had any issues as of yet. actually they felt wierd at first like it was late braking and whatnot but now the pads seem to have settled. smooth now.
i agree with boomfist tho... they don't feel the same as other trucks/cars still tho. there's always been some kind of loosness alittle. we'll see. my 01 club cab i had was great tho after the brakes were done. hard to say.
http://photos-c.ak.fbcdn.net/hphotos-ak-snc1/hs273.snc1/10035_128054379775_509549775_2287834_1010893_n.jpg
dualdakota02 is offline
post #7 of 28 Old 05-05-2009, 04:03 PM
hskrRT
nstg8tr
hskrRT's Avatar
Vehicle: 2000 R/T
Modifications: Lots 'O stuff
Quoted: 190 Post(s)
There are also common problems with the master cylinder not releasing the pressure after releasing the brake pedal allowing the brakes to drag. Usually it's only one side or the other dragging. If replacing the calipers doesn't fix the issue, then you need to try the master cylinder, and then possibly the booster after that.
hskrRT is offline
post #8 of 28 Old 05-05-2009, 05:19 PM
01SilverDak01
234 RWHP and 296 RWTQ!
01SilverDak01's Avatar
Vehicle: 01 Dakota CC 5.9 R/T
I've had the same issue with my 2001 R/T, I replaced everything from the Brake hoses, Calipers, Pads and Rotors with all top of the line NAPA brake products......
You'll get a little bit of smell and smoke while the pads "BED" themselves in at first....
I'm tempted to swap the Master Cylinder out as well just so I know I have everything taken care of.......
Ron
15' Challenger SXT 3.6, Super Track Pak
01' Dakota SVR CC 5.9 R/T
1 of 529 built for 2001
01SilverDak01 is offline
post #9 of 28 Old 05-06-2009, 12:51 AM
caulk04
Vehicle: none
Correct, just the flex lines. Flush the fluid out before doing anything, then install the new parts and bleed the system.
caulk04 is offline
post #10 of 28 Old 05-06-2009, 01:44 AM
superdaver
Vehicle: 95 Sport 5.2l/NV3500
Is the factory caliper spring still in place?
Q: is the factory spring still in place on the calipers?
Looks kinda like a spring steel bridge, supports the outside of the caliper against the rails the pads slide on.
I had the same issue on my Dad's 02 Dak, bought all new lines, calipers & pads and as we were reassembling everything I ran across the new springs which came with the pads & was like "what are these for?"
Looked it up in the FSM & sure enough somebody had done the brakes on the truck previously and left out the springs. More than likely without the spring to support it, the caliper/pad assembly got out of alignment and didn't retract/release properly.
superdaver is offline
post #11 of 28 Old 05-06-2009, 03:49 AM Thread Starter
Mas
Like I said before, I do not think the original problem was pads, rotors, or calipers..since they were already replaced and did not solve the problem. The original owner had brakes problems within he first 10K miles. Obviously, bad engineering with many others with the same problem. Kinda had to have a class action suit against a company that just went bankrupt!!
How would the flex lines contribute to the calipers not releasing?
I'm leading to think that the vacuum produced by the booster contributes to the release of the caliper when the pedal is released...and therefore, the booster is insufficient in volume for repeated brakings. Is this possible?
MAS
Mas is offline
post #12 of 28 Old 05-06-2009, 11:32 PM
caulk04
Vehicle: none
Not to say it shouldn't be on there, but that won't help the dragging brake issue. It's simply an anti-rattle clip that helps keep the caliper from rattling around and wearing on the guide pins. As soon as you step on the brakes, they straighten themselves out.
#1 - The factory rubber lines break down over time and small bits of rubber work their way into the caliper. The pressure of applying the brakes is more than sufficient to force past these small obstructions. However, these little rubber bits cause the piston to hang up and drag the brakes. Only way to solve the issue is to flush the lines out completely, replace the lines and calipers.
#2 - No, that's not possible. The hydraulic portion of the brake system works with no vacuum input from the booster.
caulk04 is offline
post #13 of 28 Old 04-25-2011, 12:46 AM
DanaRocque
Vehicle: 99 Durango SLT 5.2 V8
Im having a similar problem on my 99 Durango. I just replaced balljoints, tie-rods, CV half shafts, wheel bearings, rotors, pads, and calipers in preparation for a cross country trip. The brakes were not giving me trouble until I started fu%#& with them! Now they are dragging, not bad though. When I get out after a local trip around town I can tell one side is deff giving off more heat then normal and has the typical heated brake smell, the other side just fine. Also, noticed a lot of brake dust on the left front wheel, none on the right. Next time I take it out it might be the opposite side that drags, its hit or miss! It seems like its never both sides doing it at once though, ether left or right. I have a Master Cylinder on order hopping thats the problem. Am I missing anything here? Any Advice?
DanaRocque is offline
post #14 of 28 Old 04-25-2011, 12:50 AM
hskrRT
nstg8tr
hskrRT's Avatar
Vehicle: 2000 R/T
Quoted: 190 Post(s)
Did you flush the brake fluid when you put the new caliper on?
hskrRT is offline
post #15 of 28 Old 04-25-2011, 12:52 AM
DanaRocque
Yes, I bled until I purged the system.
