Replacing Front Shocks - Dodge Durango Forum and Dodge Dakota Forums
Go Back   Dodge Durango Forum and Dodge Dakota Forums > Technical Forums > Maintenance Forums
Maintenance Forums Keep your truck looking and running its best with this advice.
  #1
Old 04-25-2009, 09:34 PM
Sparky Sparky is offline
Vehicle: 1999 Daktoa 3.9L Reg. Cab
Reputation: 10 Sparky is just getting started
Question Replacing Front Shocks
Well, I have noticed some fluid leaking out of my drivers side front shock. I would like to replace the 2 front ones and leave the back ones for a bit later, they seem to be working fine.
I was just wondering if any of you guys had any tips for me as far as installation goes, and brands that you use.
Also, I had a front end alignment done about 3 months ago, would I need another one if I replaced the 2 front shocks? It's is just a shock and spring suspension in the front, no struts or anything.
Thanks guys!
  #2
Old 04-25-2009, 10:06 PM
caulk04 caulk04 is offline
Vehicle: 02 CC 4x4 4.7
Reputation: 239 caulk04 is a splendid one to beholdcaulk04 is a splendid one to beholdcaulk04 is a splendid one to behold
No alignment needed for a shock change.
My only advice is to hit the bolts with PB blaster at least a day before, then again right before removing the bolts. The lower bolts on the front shocks seem to break fairly often if you don't take care removing them.
__________________
Hey, does this smell like chloroform to you?
  #3
Old 05-03-2009, 12:51 AM
99R/T-Kota 99R/T-Kota is offline
Vehicle: 99 dodge dakota r/t
Reputation: 14 99R/T-Kota is just getting started
i just changed mine last weekend end with monroe reflex, i like them so far i was told they would be stiff but i dnt know what my r/t rides like with stock shocks considerin that one of the factory one i took off wouldnt even expand back out, so yeah caulk is right you shouldnt need a alignment, i personally didnt have any trouble takin the bolts out, but like he said they have been known to break,
  #4
Old 05-03-2009, 01:27 AM
sunike32's Avatar
sunike32 sunike32 is offline
Andrew
Reputation: 20 sunike32 is just getting started
Send a message via AIM to sunike32
I just replaced all four shocks on my truck as well. Just in case you break one of the lower shock bolts the size is 8mm x 30mm 1.25 pitch. Also, it wouldn't hurt to put a dab of anti-seize on them when you put it back together
__________________
1999 IB RC R/T
  #5
Old 05-06-2009, 01:06 AM
Thanks for your help guys! I was all ready to replace the shocks on the weekend, but I noticed that my front drivers side bump stop was missing...(which is why that shock is leaking... I'm assuming from bottoming out a few too many times)..so I went to a stealership today and ordered one in. Need to wait about 3-5 days for it..then I can begin! Looking forward to fixing this thing.
  #6
Old 05-06-2009, 01:35 AM
Matts00SLT's Avatar
Matts00SLT Matts00SLT is offline
Vehicle: 2000 Dodge Dakota 4x4
Reputation: 10 Matts00SLT is just getting started
u went to a dealership to buy shocks??? man i would have went to the parts store instead and gotten 2 new fronts instead of one. Might as well do both fronts while your down there and getting dirty so uk they both r good
__________________
2000 dodge dakota 4x4
4.7L V8- 31" cooper discoverer STT tires
Spintech pro street muffler dumped
-comming soon-
Tint front drivers and passenger windows
  #7
Old 05-06-2009, 01:41 AM
Anthony's Avatar
Anthony Anthony is offline
Yes it's a lowered 4X4
Vehicle: 2000 Dakota CC Sport
Reputation: 29 Anthony must have done something right
Send a message via MSN to Anthony
I understand he bought a bump stop from the dealership not the shocks.
Sparky, if you can wait a bit, watch the Canadian Tire flyers for sales on Monroe Reflex shocks. I see them every few weeks for 50% off. That's where I bought mine.
__________________
2000 Dakota CC Sport Plus, 4X4, 4.7, 5spd Stick, 3.55 LSD. Mods, naahhhhhhh....
2001 Mustang GT Bullitt, True Blue, 1 of 23 in Canada.
  #8
Old 05-06-2009, 11:43 AM
dualdakota02's Avatar
dualdakota02 dualdakota02 is offline
Vehicle: 2002 dak QC 4x4, 4.7 v8
Reputation: 18 dualdakota02 is just getting started
good to know ill be doing mine soon too
__________________
http://photos-c.ak.fbcdn.net/hphotos-ak-snc1/hs273.snc1/10035_128054379775_509549775_2287834_1010893_n.jpg
  #9
Old 05-06-2009, 04:29 PM
MrMcQ's Avatar
MrMcQ MrMcQ is offline
Red Rango
Vehicle: 03 Rango R/T 4x4
Reputation: 41 MrMcQ must have done something right
Garage
I went with Rancho shocks because a found a killer deal on them online (they where the cheapest at the time). I have a 4x4, and the fronts where a bit of a B*tch for me, even with it jacked. Had to compress the strut to get it into place because it has 1 vertical bolt and 1 horizontal bolt.
__________________
5 Door Whore #204 - Superchips, Taylor 8MM wires, NGK G-Power Plugs, 14" air hat, Gibson GP301 Headers, Rancho RS5000 shocks.
In-Progress: Clutch Fan Delete, better e-fan, Ford 4-hole injectors, and much more...
  #10
Old 05-06-2009, 09:30 PM
hmmmm..a little confusion here...
Bump stops were from the dealership
Shocks were from a part store (Buy 1 get the 2nd 50% off)
Thanks for all the help and tips guys! It looks like the shocks on my truck (2wd.) are pretty straight forward to replace. 1 upper nut and 2 lower bolts to remove.
  #11
Old 05-06-2009, 11:28 PM
MrMcQ's Avatar
Red Rango
Garage
That's how mine are setup but for some reason with truck fully jacked I had to compress the shock to clear the lower arm for install
__________________
  #12
Old 05-08-2009, 12:27 AM
70Cuda383's Avatar
70Cuda383 70Cuda383 is offline
Don't be "That Guy"
Reputation: 181 70Cuda383 is a name known to all70Cuda383 is a name known to all
here's a tip. take the nut off the top of the shock BEFORE jacking up the truck. supposedly, the weight of the vehicle on the shock helps to keep the rod from spinning with the nut.
I had mine sky high in the air when I did it, and I had to vise grip the rod while wrenching the nut off.
  #13
Old 05-08-2009, 05:17 AM
JuicedDakotaRT's Avatar
JuicedDakotaRT JuicedDakotaRT is offline
Vehicle: 1998 Dakota R/T
Reputation: 26 JuicedDakotaRT must have done something right
Send a message via AIM to JuicedDakotaRT
good call! ^^^ my bilsteins that i got with my hotchkis kit(discontinued good bilsteins) shit the bed i threw some normal bilsteins in. so i get the truck up and everything off, rod spinning..... allen key at the top of the rod rounded out, and vise grips wouldnt hold it. had to tear apart the front end on both sides, pry the upper arm up with a crow bar while my friend was taking a grinder to the shafts. royal PITA
__________________
1998 FR Dodge Dakota R/T
2000 BK Dodge Durango R/T
Mods- Too many to list
  #14
Old 05-08-2009, 11:22 AM
bwdakrt
Posts: n/a
I have a special 3/8" drive socket that fits the top of the shock that I've probably had for 30 years or more. You hold the top nut with a 9/16" wrench and turn the shock shaft down thru the nut. I very seldom use it but it makes replacing front shocks a breeze!
  #15
Old 05-15-2009, 07:12 PM
Talking
First off, thank you to everyone for the help. Everything went well, didnt snap any bolts, but I had to replace a sway bar link that was rotting out. (well, just the bushings were) on the passenger side. I had a hard time getting the link out of the frame because of the tapered end on the link and the tapered hole in the frame..... seemed to stick in there pretty good! . One heck of a job, but it was fun and I enjoyed it!
You may not post new threads
You may not post replies
