| Register | Home | Forum Extras | Website Features | Garage | Calendar | Search | Today's Posts | Mark Forums Read | Auto Loans |
| Troubleshooter's Forum A place to ask technical questions. |
Thread Tools | Rate Thread | Display Modes |
#1
belt squeaking?
every time i start the car i hear a horrible squeaking noise from under the hood..every time i accelerate the squeaking noise gets loud, but after i hit the break it goes away until i let off the brake and accelerate again...any ideas of what this is?
| Sponsored Links | ||
Advertisement | ||
#2
Have you replaced the belt? Your belt tensioner may be shot also.
#3
any leaks? i had the same prob but mine was a blown gastket on the thermostat
#4
loads up only on acceleration? that's odd. could be additional load on the electrical system putting an extra load on the alternator making the belt squeel...but that's not likely.
beats the hell out of me why it only happens on acceleration, other than your putting effort into spinning all the accessories faster, which loads up the entire belt system, and makes a squeel, and as you coast/brake, it's all just "coasting" back down. regardless, check your belt, make sure it's not glazed over from excessive heat/age. if it's got 70K miles or more on it, or it's more than 5 years old, change it. if it's still there, check your tensioner, make sure it's still pulling the belt tight. While you have the belt off, feel all the pulleys, make sure none of them are "dry" when you spin it by hand, it should have no wobble in it, and it should feel "gummy" for lack of a better term. basically, if you spin it by hand, it should only spin over 2, maybe 3 times before stopping. this means there's still good grease in the bearings. if you spin it and it just goes and goes and goes, then the bearings are dry, and shot...and needs replaced. |
#5
My tensioner looks wobbly and makes noise. How would I change it out?
__________________
![]() '99 Dakota SLT 5.2L- -Edelbrock Breather- -Edelbrock Ceramic Shories- -Spintech ProStreet- -MagnaFlow Cat.- -Cragar 441's- -BFG Radial T/A's- -Pioneer Head Unit- -Hypertech- -Mopar Tonneau- -Crystal Headlights & Corners- -Smoked Tails- |
#6
If the tensioner is bouncing or shows a lot of movement while the engine is running, you may need to replace the entire tensioner assembly, which is also very easy to do. |
#7
![]() Truck's falling apart
__________________
#8
#9
Same thing happened to me. Make sure the serpentine belt isnt cracked (on the bottom side) and make sure the belt done have too much play.
#10
I let a garage service the alternator with new bearings. As good as new
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | Rate This Thread |
