Front Clunking - Dodge Durango Forum and Dodge Dakota Forums
Go Back   Dodge Durango Forum and Dodge Dakota Forums > General Parts Forums > Suspensions - Lifted & Lowered
Suspensions - Lifted & Lowered Drop Kits, Lift Kits, Shocks and More
  #1
Old 04-01-2009, 12:17 PM
JasonA's Avatar
JasonA JasonA is offline
Vehicle: 1997 Dakota 5.2L
Reputation: 10 JasonA is just getting started
Front Clunking
I'm starting to get frustrated with the rattling from my front suspension, and for the life of me, I can't figure out what it is. Here's what it does: it seems that primarily when the front tires hit a sharp bump at the same time (like a small frost heave), something rattles under the front suspension. It happens only when the fronts hit the bump, not the rears. And it doesn't have to be much -- even just a really thick crosswalk tape will do it. On larger bumps, it's all quiet. And it seems like when either of the front tires hit a bump at different times, it doesn't do it.
What I've done: I've replaced a lot. First thing I did was new shocks, Gabriel Ultras. These ride really good with the stock Sport springs. A good match there. But no fix. I also put on new sway bar end links, to no avail. A month or two ago, I torqued down the upper control arm bolts, because I know those have a tendency to loosen up. Just this last weekend, I replaced the lower control arms with ones from someone on this forum, reported to have only 20k miles on the arms. The bushings in the replacement arms look good...much better than my old bushings, that's for sure. I also put in new greasable lower ball joints. When I did that, I also greased the tie rod ends...mine have Zerk fittings. Maybe that means they've been replaced before? I know the upper ball joints are fairly fresh, done at the dealer with Mopar parts not too long before I bought the truck a year ago; they do not have Zerks. When I did this work, I also put in some R/T coils with new Mopar spring rubbers. The ride is moderately firmer now, but it's still pretty good. I torqued everything down after the install, at curb height. And the rattling noise is still there, with the same symptom.
What's not been touched: the upper control arm bushings (with 173,000 miles I'd suppose), and the sway bar bushings.
What I've done to try to narrow it down: early on, I drove around the neighborhood with no shocks and no sway bar, and the rattle was still there. To me, this really sounds like a sway bar thing, but this is not a low clunk sound...something is rattling, and from the sounds of it, it's small and metal. It sounds very much like you had a small length of metal link chain, and when you give it a quick jab or pull, that's the noise.
Anyone had upper control arm bushings make this noise? That's about the only thing left in the front suspension that hasn't really been touched yet. Well...and the brakes. I mean, they've been replaced before, but was a few years ago. There's still a moderate amount of pad material left. Would the pads make a jiggling/rattling noise like this?
I'm at my wit's end! Anyone with any ideas?
__________________
1997 Dodge Dakota Sport Club Cab (Emerald Green Pearl), 5.2L V-8, 44RE, 3.55s
Dak's birthday: 01/28/97 at 10:00 pm.
  #2
Old 04-01-2009, 12:53 PM
minilowz's Avatar
minilowz minilowz is offline
Quad Squad Member
Vehicle: 03 Dakota Quad 2wd
Reputation: 11 minilowz is just getting started
Does it sound like its coming from the steering? or does the steering wheel shake when you hear the rattling? Mine was doing that, I replaced the lower steering shaft and no more rattles on bumps
__________________
03 Quad 2WD 4.7 5Sp Auto, Street Scene Front Bumper,ARE Topper, Silver R/T Wheels 255/60/17, K&N FIPK, DIY Thrush Exhaust, Kenwood X990 Stereo, Child Seat
  #3
Old 04-01-2009, 01:35 PM
suffolk_mopar's Avatar
suffolk_mopar suffolk_mopar is offline
Vehicle: `04 dak qc
Reputation: 11 suffolk_mopar is just getting started
Send a message via Yahoo to suffolk_mopar
i had a simular problem on my ex`s 03 qc 4x4. replaced a bunch of shitt and could never figure it out. come to find out the brake caliper bolts had worked loose on the right side and the caliper was bouncing around making a rattling noise from hell on every bump she/i hit. on first glance it didn`t look loose, so i put a soicket on the bolts and they were loose as hell.
__________________
04 qc 3.7- viper fan,fast man t/b,pcm flash,borla,
p.a. body lift, runnin 265/75 a/t`s.
  #4
Old 04-01-2009, 03:07 PM
JasonA's Avatar
You know, I never checked the brake caliper bolts...I'll check those. What is the internal hex size for the caliper bolts? And thanks for the suggestion for the steering shaft. It's not been replaced that I know of. I'll check that also. Was there an indication that the shaft was it (any play that you could detect by shaking or wiggling it)? I think there is actually a TSB for my model year regarding the steering shaft, but as I recall, my symptoms didn't match those in the TSB; I'll have to look at it again.
Thanks...and keep the suggestions coming!
__________________
  #5
Old 04-01-2009, 03:11 PM
minilowz's Avatar
Quad Squad Member
on my 03 and my sister's 00, the only indicators were the clunking, no play in the steering, just had the clunk during bumps in the road, it was the lower shaft, which has some sort of a bushing in it(I think it may be for crashes so it collapses) the truck drove fine just annoying clunking
__________________
  #6
Old 04-02-2009, 12:21 AM
JasonA's Avatar
I just took my sway bar completely off a few minutes ago and checked and that made no difference. The bushings on the bar are trashed anyway...I plan to replace with polyurethane ultimately. So I diagnosed sway bar out again (I was sure I tried that before, but wanted to re-check).
I wonder if it could be the upper ball joints. My truck wasn't involved in the recall, but I know some of our trucks were. The recall says that the worn upper ball joints could create a clunking sound that may or may not be heard by the vehicle occupants. For those of you who DID have recalled ball joints, do you recall the symptoms of bad upper ball joints? If mine are bad, it wouldn't be too much trouble to replace them -- the arms already have bolt-in ball joints in them (by the Dodge dealer, non-greaseable).
I'll check the brake caliper bolts this weekend.
__________________
  #7
Old 04-02-2009, 01:59 PM
Jackedak03's Avatar
Jackedak03 Jackedak03 is offline
Up then Down then Up then
Vehicle: 2003 Dakota Quad Cab 4x4
Reputation: 14 Jackedak03 is just getting started
I was going to say steering shaft as well.
__________________
2003 Dakota QuadCab SLT 4x4 4.7 V8 - Traded
2004 Ram 2500 QC 4x4 HEMI w/4.10's -Traded
2011 Dodge Charger - Company Car
2003 Jeep Liberty Sport - Family Hauler
1999 Ram 2500 QC 4x4 5.9 - 3" BL, 2.5" Spacer, 315's in progress
  #8
Old 04-03-2009, 05:46 PM
JasonA's Avatar
I believe I've found my clunking. I jacked up each control arm separately today at lunch and tried to wiggle the tire at the 12:00 and 6:00 positions. The right side one has some play. The control arm is moving a bit on the rear bushing. The UCA shaft bolts are tight (I torqued those down pretty good a month or two ago), but it looks like the bushing itself is shot. But I was never able to tell until I checked for play with the wheel and tire mounted up (more leverage I guess).
So I guess I'll take the UCAs into the machine shop and have them press in new bushings.
__________________
  #9
Old 04-29-2009, 12:55 AM
IWA2002's Avatar
IWA2002 IWA2002 is offline
Vehicle: 2002 DODGE DURANGO
Reputation: 10 IWA2002 is just getting started
FYI- Might be cheaper to change out the whole control arm, most of them include ball-joints and bushing..
You may not post new threads
You may not post replies
