Rear Disc Installation
91K views 116 replies 48 participants last post by  GladePlugIn
#1 · (Edited)
After completing my rear disc installation I decided to post up all of the information I gathered. This post should answer most of the questions asked in regards to converting a drum brake equipped 1997-2004 Dakota/Durango to rear disc. The information has been gathered from my own experience as well as other posters. I used some images from one of 70CUDA383 posts and information from one of Duner posts for Jeep rear disc. Thanks for the info guys!
If anybody has anything to add, post it up and I will edit this thread.
This thread deals with factory rear disc options only and does not deal with any of the aftermarket offerings.
In short, there are no bolt on options for factory rear disc on our drum brake equipped Dakota/Durango's regardless of year of manufacture. All of the options require some kind of modification. Listed below are the options, positives and negatives to each, as well as what is required to make them work.
The absolute best way to swap over to rear disc is to get the complete axle assembly out of an 03-04 Dakota/Durango. If you are swapping from Durango to Dakota or Dakota to Durango the only thing that needs to be changed is the shock mounts. This is a piece of cake when compared to changing the axle flanges.
The primary reason disc brakes will not bolt onto drum brake rear ends without mods is due to the backing plate flange location. The pictures taken by 70CUDA383 show the differences in flange placement.
From these pictures it becomes obvious why the disc brake backing plates will not simply mount onto a drum brake rear end. That leaves us with needing to modify something to make this swap possible.
1. Mid 90's Jeep Grand Cherokee rear disc. This is probably the easiest swap as the Jeep uses the same axle flange location as the drum brake rear ends in our Dakota/Durango's. Duner has completed this swap and had this to say regarding modifications.
Rotors need to be redrilled for the 6-lug bolt pattern.
The center of the backing plate needs to be opened 05" to clear the larger axle tube.
The mounting holes for the backing plate need to be opened up .0625 to mount on the axle flange.
Parking brake cables have not yet been installed but, I can't see that being very difficult.
Rotors on the Jeep are a little bit smaller than what came on the 03-04 Dakota/Durango, they measure 11.2"
These rotors are solid.
This brake setup will fit under 15" wheels.
2. 03-04 Dakota rear disc. The only modification that needs to be done to use these brakes are axle flange relocation. This is not a particularly easy modification. It can be done but it is not fun.
Axle flange needs to be relocated.
Parking brake cables need to be from a vehicle with the same chassis length, they can be found at Rock Auto or obviously the dealer.
The rotors are 12.1" in diameter and are solid.
This setup uses updated single piston rear calipers.
The backing plate has an integrated caliper mount. It is a single piece unit.
This setup requires 16" or larger wheels.
3. 03 Durango rear disc. Like the 03-04 Dakota rear disc the axle flange needs to be relocated. The 03 Durango rear discs share nothing in common with the 03-04 Dakota rear discs.
Axle flange needs to be relocated and flipped on one side.
The rotors are 12.1" in diameter and are ventilated.
This setup uses what appears to be the same caliper that was used on the mid 90's Jeep Grand Cherokee. It is a single piston caliper.
Backing plate and caliper mount are separate pieces.
The photos below show the differences between the 03-04 Dakota rear rotor and the 03 Durango rear rotor courtesy of Rock Auto. 03-04 Dakota on top with the 03 Durango below.
There may be other options. If you know of any that will work, post them up.
Well after having all this new knowledge if you still want to proceed with swapping your rear drums for discs follow below and I will show how I did it with 03 Durango rear discs.
Before starting you are going to need a pair of these. I cut these on our CNC machine when it became obvious I would need them. They were made from 3/8 plate steel. Trying to remove the factory flanges for reuse is not something I wanted to attempt.
First thing I did was remove the studs. They can be knocked out with a hammer fairly easily. Don't worry about damaging them, they are too short for the disc brakes and will need to be replaced with the proper length stud.
Don't forget to stuff some rags in your axle to protect the bearings.
Below is the stock flange before any work has been started.
#2 · (Edited)
The first cutting operation was done with a cutoff disc on a 4 1/2" angle grinder. I used this to removed the bulk of the flange so that I would not need to do too much grinding. Sorry for the poor picture quality.
Next step was removing the bulk of the flange with a grinding wheel. This was also done with a 4 1/2" angle grinder. This was slow work. I was really being careful not to cut into the axle tube. I got it down to about 1/16 " all the way around before proceeding to the next operation.
I then installed a 40 grit flap disc on my angle grinder to get the flange down to the same thickness as the axle tube itself. The flap disc is far more forgiving than a rigid grinding disc.
I finished the axle tube smoothing with a DA sander starting with 40 grit paper followed by 80 grit and finishing with 120 grit. This allowed me to get the axle back to a somewhat round state.
With all the grinding finished it was now time to set the flanges. I first installed new studs from an 03 durango that I purchased from the dealer. They were about a dollar each. We then tacked them in place at 2" to get an idea of what would be need to get my caliper bracket centered on the rotor. After a few tries we ended up at 1 13/16 for my 03 Durango pieces. This is time consuming in that you need to remove the axle each time you reposition the flange. Flange placement is absolutely critical. If your flange is not perfectly square on your axle tube the brake pads will not make even contact with the rotor. This was the most difficult and time consuming part of this install.
The axle flanges on the Durangos are flipped with one side having the wide pattern at the top and the other having the wide pattern at the bottom.
Once I was convinced that the flanges were square to the axle housing we finish welded them.
We did what we could to minimize warpage by using wet rags to cool between welding passes. The flanges still warped slightly. I needed to tap the studs back into alignment for the backing plates to slide on the axle smoothly.
After getting everything bolted up we checked disc run out when compared to the caliper bracket. Fortunately everything stayed square. Shown below is the completed installation.
This project took me about 12 hours to complete with some help from my friends at H Town Performance in Henderson Nevada. This does not include CNC time or parts running.
I smoothed my calipers and caliper brackets before coating them with VHT caliper paint. The logo outlines were cut from vinyl then spray painted with VHT silver caliper paint. The rotors are Ebay cheapies. I will be curious too see how they hold up, if they warp after the first time I apply my brakes I will be sure to let everyone know!
Now that I am finished I guess the question is was it worth it? To me it was. My rear end was already rebuilt with 392 gears, LSD, and all new bearings. It would have been too expensive to switch everything over to a 03-04 rear axle. With that being said, If I had it to do over again I would have gotten the axle out of the Durango I got the brakes from and built that.
I hope this post comes in handy for those that are contemplating this swap.
#105 ·
If someone would have some rings built about the thickness of the depth difference of the drum axle and the disc axle, we could adapt the Dakota/Durango discs to a Drum brake axle with out cutting or welding, and then use counter suck bolts on adapter rings to screw to existing axle ring, but there would have to be eight holes in each ring with four counter sunk and four with new bolts to attach to disc backing plate, so the discs would not be clocked the same as stock, but it would not be a big deal and if the other four were counter sunk on the flip side, they would work on a Dakota and Durango backing plate just by flipping it over.
#3 ·
Great write-up and good information to know!
Reactions: martinbuilt
#6 ·
Sure, those kits are "bolt on in an afternoon" kits, but at nearly $1,000 for them...they better put themselves on!
I have less than $300 tied up in this brake swap so far. $200 for a complete axle with everything I needed to include parking brake cables (but it's an 8.25, not a 9.25 so NO, I can't just swap axles!) --plus brand new calipers ($60) and a few cans of spray paint (then, once i sell the rest of the axle with the drum brake stuff installed on it...subtract that from the total cost of my swap)
maybe $10 for the steel to make new flanges from, and the cost of materials used (torch gas, grinding stones, etc.)
not trying to knock the pre-engineered kits, but for about 1/3 the price and a day or 2 longer, you can have the factory kits knocked out, and save $600 for other mods:mullet:
#7 ·
You might be paying almost a 1000 bucks for a kit.. but your not taking the cost of your time into consideration or the cost of your truck being out of comission in order for you to custom make this swap...you said it yourself that you still hand worked stuff trying to make it fit right... i think it might be worth it to spend the extra money and be able to do the sawp in a day vs a week or 2... but thats just me
#8 ·
yes, that's a valid point, that your own time does cost money, but that all really depends on how you view your truck as well, to include the time spent working on it.
if it's a hobby, then you don't really care how long a project takes, especially if it's not your primary mode of travel or work vehicle. like me. I drive a roller skate to work and I have an un-modified, bone stock quad cab that i use for trips to the hardware store, etc. I don't really care if my truck sits all winter while working mods to it. that time is "free time" because it's hobby time, I'm doing something I enjoy doing. it's definitly not work.
but if your truck is needed for work around the house, or if it's one of your primary means of transportation, and you cannot afford to have it parked for a week or 2...then yea, that's where a pre-engineered, bolt on kit has it's benefits.
it's good for someone who wants to swap rear drums to discs, to know ALL the options out there, what they require, cost, etc. and then they can make the informed decision themselves on what to do!
I keep going back and forth myself on the viper fronts...do I want to buy the kit and have big ass, viper front brakes, or is the stock set up from an 03/04 going to work for me? 12.2" vented rotors should be more than enough for a street driven truck that will probably NEVER be autocrossed--then again...those large rotors and viper calipers are sexy!:jester:
#12 ·
Dodgebigblue,
If you already have your rear end setup with 456 gears your best bet is to go with the Jeep Grand Cherokee rear disk setup. Anytime you pull gears out of one rear end and put them in another they will need to be setup. The Jeep rear disk is very easy to setup and will not require any welding.
I would cut some flanges for others if needed but they would not be cheap. The problem is that CNC cutting steel is not a very efficient way to make those types of parts. The CNC makes the nicest parts but the most efficient (read that profitable) way to make these parts would be to water jet cut or laser cut. I do not have either of those.
I do have the CAD for the flanges that I can email so that anyone could get a quote from a local shop or have accurate measurements if they would like to make their own.
#16 ·
Here's my pics from the swap. didn't take me 2.5 hours to grind off the old flange, but it was definitly the better part of an hour.
tacked the new one in place, made sure it was square, mocked it all up, check fine, took it all apart and burned it in solid, and put it all back together!
my new flange might not be as pretty as scott's, but remember, he used a CNC machine. I used a cut off wheel and an electric hand held drill.
This just shows that you don't need a nice machine shop to do this swap!
tools used: standard wrenches, sockets etc, 4.5" angle grinder, 3/8 chuck electric drill, and a cheap 110v flux core wire feed MIG welder.
#17 ·
Nice work! Just shows what can be done with a little effort and a few tools.
Doesn't matter regarding how pretty the flanges are they provide the same function. They can't be seen anyways.
Have you had a chance to drive it and compare how well the truck stops compared to the factory drums? It will be a while before I get the chance to test mine and was curious what you thought.
#20 ·
I found this kit and all you have to get is calipers, pads, hoses, and ideally an adjustable proportioning valve. I've used one of their kits before on an old 79 Bronco I had, and I'm going to be using another of the same kit on the 9" Ford going under my 99 4x4.
http://www.tsmmfg.com/2552.htm
#21 ·
That kit price is kinda high when you can get recycled parts or even a complete rear end for the price of the incomplete kit. Not to mention they have smaller rotors then the 03 and up....
I dont like using aftermarket kits. What happens when you need to replace a rotor for some reason...... I would stick with 03 swap but thats just me. My brakes are something I dont mess around with... I like being able to stop and get new parts if/when I need to. I am VERY hard on brakes.
Dodge Dakota and Durango rear disc brake kit includes:
brackets, bolts, and new 11 1/4" vented rotors. Link for info on ABS
Part Number 2552 $259.95 pair
#23 ·
You can get the rotors calipers and pads anywhere with the kit that I posted a link too also. The calipers and pads are off of a late 70s early 80s GM G-body, Monte, Cutlass, Regal, etc. And I had the pn of rotors at the house for if I had to relplace them on my 79. The reason I'm not even considering the Jeep or 03 brakes is cause I'm using a 9" Ford under the rear of my truck, would be a good bit harder to get either of those braking systems on that axle then the bolt on kit that I'm using.
#24 ·
heres an idea...with you guys that have the drum axle...and can either get the 03/04 dak brakes or the jeep brakes....which will be the best option....
just make a spacer for the backing plate instead of cutting the old plate off and welding a new one
now if all you can get is the durango ones...have fun
anybody have any measurements for the newer jeep brakes?
#28 ·
I don't think you understand the problem with the alignment...
on BOTH the Durango and Dakota 03/04 rear disc brakes, the mounting flange is 5 cm from the end of the axle tube. on the drum brake axles, the flange is 3 cm from the end of the axle tube...so if you're going to take the disc brakes that are built for a 5cm "backspacing" and put it onto an axle with a 3cm mounting flange...it's goingto be 2cm TOO CLOSE to the end of the tube...not sure how a spacer is going to correct that problem! the only solution is to either cut the caliper mounting bracket into the shape of a "C" and slip it on BEHIND the flange for the drum brakes, and THEN use a spacer, or, cut off the old flange, and weld on a new one.
#26 ·
Very true that most of the braking is provided by the front brakes. I did notice a pretty big difference after adding the disc brakes - but that could partly be due to the fact that my original drum brakes were out of adjustment after doing roughly 700 burnouts in addition to 65k of actual driving.
#27 ·
"I did notice a pretty big difference after adding the disc brakes - but that could partly be due to the fact that my original drum brakes were out of adjustment after doing roughly 700 burnouts in addition to 65k of actual driving."
LOL:jester:
#31 ·
Huh, very interesting info. When i swapped from drums to discs i went a different rout. I didnt do any welding or have to flip one of the mounts. My axle was from a 98 dakota that had drums (i think it was a 4x4). I just cut off the dust shields and ground down the caliber brackets to clear the rotors. The rotors and caliber brackets are from a 2004 or 2003 dakota. Here is a pic prior to cutting off the dust shields and grinding for clearance. Been running if for about 10k miles now with no issues.
SPP=Scott, do you still have the measurements for the axle flange or are you able to get more made?
Dodgebigblue, like i said on the other site I don't mind helping ya out with the swap.
