| Register | Home | Forum Extras | Website Features | Garage | Calendar | Search | Today's Posts | Mark Forums Read | Auto Loans |
| FAQ's, Tips & Tricks Helpful technical information. |
Thread Tools |
Rating:
Display Modes |
#46
If you get lower ball joints where you can remove the boot when you press them in it will save you all the hassle of this job.
| Sponsored Links | ||
Advertisement | ||
#47
If you have an air chisel you can knock those rivets out in a heartbeat.
#48
doing the upper and lower ball joints on both sides of my dakota i found the easiest way to knock the rivit heads off was to cut a groove in the center then use a air chisel and i just did those today
#49
I'm just having hell getting the lowers out............Got to the last one and my dadgum balljoint tool broke.............
#50
Sorry I should have clarified getting it out of the spindle the u tool broke. As for removal of the lowers if you press it and it doesn't move then take a 3 lb sledge and hit the housing it is held in. Mine were so tight I almost broke the damn press. |
#51
Excellent info in this thread!
Just to add an alternative for the lower ball joints - you can pick up complete lower control arms for around $110-120 per side, which include a new ball joint, and has the advantage of replacing the arm bushings at the same time. Although it is more expensive than just replacing the ball joints, it is a much simpler install, and still a huge savings over having the shop install the ball joints.
__________________
1998 Supercharged Durango 5.9L | 256whp/332tq @ 4psi 2000 Twin-Charged Buick Regal GS | 12.5 @ 110 |
#52
Wow at oreillys they told me they were $250 a piece.
#53
I believe that. Some brands are a lot less. Dorman is $120.79 at rockauto, and ebay has them for a little less (especially if you go through bing.com and get the 8% off).
Edit: I noticed you have a 2003, which is $143.79 at rockauto. The 98-99's are cheaper.
__________________
#54
That Bing deal is saweet!
Are you guys having problems getting the rivets off? I just used a 4 1/2" angle grinder with a new wheel and I know I didn't spend more than 45 seconds on each rivet head before they just fell out. P.S. I don't know when I last checked on this thread but just so ya know my super cheapo eBay front end parts are still working flawlessly and i've put 30k miles on in the last year.
__________________
1999 Durango SLT 4X4 5.2l - 2" Torsion Bar Lift - Two Tone Leather - CD/Tape Player - Infinity Sound System ![]() |
#55
Hey fellas! I know this thread is old but I need some help. I have a 99 durango 4x4 and am removing my steering knuckle to replace it. knuckle brake threads striped. For some reason the damn ball joint won't pop out of the lower knuckle hole. Everything is disconected except the lbj. I have tapped with a sledge hoping it would drop out. I have also broke my lbj by prying with a fork separator. How do I remove the knuckle from the lbj? I need good dodge guidance! Sry if this is posted elsewhere. Thanks in advance all help is welcome!
#56
you will ruin your lower balljoint, but get a propane torch and heat the shit out of the balljoint stud and wack the top of the nut with a hammer (or use the fork) (i also hear locktite has this freeze stuff that works great too) |
#57
OMG! I'm an idiot. I think my frustration clouded my thought cause I didn't even think of that. Thanks a bunch. I was stressed thinking of ways to do it. I gotta get a new lbj now lol. I can't wait to get the new knuckle on so I can drive my D again. I'm so low in my LHS.
__________________
99 Durango SLT - Crystal Headlamps, 2 piece bra, flowmaster 40 series deltaflow muffler, rain guards, pioneer/eclipse/infinity stereo system installed. More to come
#58
Holy hell did removing the lbj give me a headache. My newish angle grinder took a poo on me so I finished grinding the lip of the lbj out with my 3" wheel cutter. I broke my hammer but I sure as hell pounded the lbj out first. Having trouble putting the new lbj back in, but tommorrow is a fresh day with another 12 pack lol. Thanks again for having this thread here!
__________________
#59
i dont have a press and i cant rent one around me, is it still do able without it?
__________________
![]() ![]() ![]() ![]() ![]() ![]() 2003 dak c/c 4x4 3" b/l, t/c, 305 mtz's, cai, 180 stat...
#60
install, stick em the freezer for a couple hours, then *quickly* install. or pull LCA(s) and take to a shop and have them press in/out.
__________________
1999 Dakota R/T (mild to heavy mod) 2006 Magnum SRT8 (not *yet* modded) ![]() 2004 Dodge Caravan SXT.... Momy Mobile ![]() ![]() BEATER: 1991 Honda Civic DX 4dr ![]()
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | Rate This Thread |
