max boost on 5.2? - Dakota Durango Forum
Power Adders Parts Info Links : Superchargers * Turbochargers * Nitrous Oxide
post #1 of 43 Old 03-13-2009, 05:58 AM Thread Starter
Blue 12
Vehicle: 94 Dakota SLT
max boost on 5.2?
hey guys, on a stock 5.2 magnum, what is the max amount of boost i can run on 91 octane? also how much timing retard is required as well as what AFR? does it matter if the boost if from a turbo or super charger?(i think im set on a turbo though) how much more boost or timing can be run with an air to air intercooler?
thx!
94 Dakota SLT 5.2 4x4. dual exh, 6 in lift, 38x12.5in tires...possible MS/Turbo project
01 ZX-12R nitrous powered street/drag bike. 9.02@157 in the 1/4
Blue 12 is offline
post #2 of 43 Old 03-13-2009, 06:25 AM
blwn318
Mods Addict
Vehicle: 00 dakota, 99 ram 2500
Modifications: alot
does not matter where the boost comes from. the intercooler will drop your boost levels 2-3 psi depending on what style you run. as for boost numbers.... all depends on your set up. stock i wouldn't push more then 6-8 psi.
blwn318 is offline
post #3 of 43 Old 03-13-2009, 10:07 AM Thread Starter
Blue 12
cool, i didnt think so.
so if i were to run an IC i would measure the boost pressure after the IC?(or that 6-8 psi would be 3-6 psi)
Blue 12 is offline
post #4 of 43 Old 03-13-2009, 01:18 PM
TheOtherDodge
TheOtherDodge's Avatar
Vehicle: 2000 Dakota
Quoted: 14 Post(s)
You should run the pressure from the maifold.
If you need a BTM or FMU set up, I have both for sale in the classifieds.
Mercedes E55 AMG: 11.80 @ 117.9
94 Dakota, 390 sb, 76mm turbo: 9.97 @ 133.33
00 Dakota QC, 5.9, M1, 6lb Powerdyne: 13.9 @ 98.38
TheOtherDodge is offline
post #5 of 43 Old 03-13-2009, 02:22 PM
Fast360Dak
Fast360Dak's Avatar
Vehicle: 96' Dakota Sport
Modifications: Go faster stuff
Send a message via AIM to Fast360Dak
I ran 10 psi on a stock 318 block and cracked it.
96' Lapis Blue Dakota Sport - 360 Swapped, Single Turbo, TKO600
Daily -00' F-250 - 8.5" proComp lift w/37"s on Dubs.
SpeedFab www.racemagnum.com
Fast360Dak is offline
post #6 of 43 Old 03-13-2009, 02:32 PM
blwn318
Mods Addict
Modifications: alot
yes but yours broke due to the homosexuality of the truck. it would rather not exist then power a genII
blwn318 is offline
post #7 of 43 Old 03-13-2009, 07:14 PM Thread Starter
Blue 12
lol....
im actually going to be using MS to control fuel and ign. what size injectors should i be using with normal fuel pressure and will the stock pump flow enough volume?
Blue 12 is offline
post #8 of 43 Old 03-13-2009, 07:33 PM
blwn318
Mods Addict
Modifications: alot
upgrade the in tank pump and put a inline aux pump as well. i ran mine on low boost with 19lb injectors for a min. then put in larger ones.
blwn318 is offline
post #9 of 43 Old 03-13-2009, 07:46 PM Thread Starter
Blue 12
why would i need 2 pumps?
Blue 12 is offline
post #10 of 43 Old 03-13-2009, 07:49 PM
Fast360Dak
Fast360Dak's Avatar
2>1
post #11 of 43 Old 03-13-2009, 07:56 PM
blwn318
Mods Addict
Modifications: alot
the stock pump will not flow enough when you get into boost. you run a aux pump to up the pressure with boost.
blwn318 is offline
post #12 of 43 Old 03-13-2009, 07:58 PM
Duner
Turbo Dakota Junkie
Vehicle: '00 4.7 CC, '99 RT RC
Modifications: Motorsports
I wouldn't even try running more than 7 or 8 psi on 91 octane without some sort of timing retard.
Duner is offline
post #13 of 43 Old 03-13-2009, 08:03 PM Thread Starter
Blue 12
if you buy a replacement in tank pump, why not just get one big enough to avoid buying an inline pump??
MS can retard as much timing as i want
Blue 12 is offline
post #14 of 43 Old 03-13-2009, 08:04 PM
blwn318
Mods Addict
Modifications: alot
you can do that if you want. i have two just cause it made it easier to plump the FMU.
blwn318 is offline
post #15 of 43 Old 03-13-2009, 08:17 PM Thread Starter
Blue 12
i wont be using an fmu, so 24 # injectors? larger?
thx
Blue 12 is offline
