Go Back   Dakota Durango Message Board > General Parts Forums > Power Adders
Home Register Forum Extras Website Features Search Today's Posts Mark Forums Read
Power Adders Parts Info Links : Superchargers * Turbochargers * Nitrous Oxide
Dakota-Durango.com is the premier Dodge Dakota and Durango forum on the internet. Registered Users do not see the above ads.Please Register - It's Free!
  #1
Old 03-11-2009, 01:05 AM
KotaKid287's Avatar
KotaKid287 KotaKid287 is offline
Chevy SUCKS!!!!!!!
Vehicle: 02 Dakota 99 Dakota 4x4
iTrader Rating: (0)
Reputation: 18 KotaKid287 is just getting started
How well do 4.7s handle N2O?
I'm thinking about shooting some laughing gas to my truck for the track just to try to get a halfway decent time out of it without going back to a 4.56 gear right now. Has anybody been running nitrous on 4.7s? How well have they held up? What kind of shot could I get away with without heavy mods?
__________________
Reg Cab Club member #133
02 Dakota 2wd RCSB 4.7 45RFE Doetsch 3" lift 31x12.50 Pro Comp ATs
99 Dakota SAS 4x4 318 Dana 44HP front 9" Ford rear
  #2
Old 03-11-2009, 01:22 AM
mthandt's Avatar
mthandt mthandt is offline
Vehicle: 2002 Dakota QC
iTrader Rating: (10)
Reputation: 82 mthandt is a jewel in the rough
Send a message via AIM to mthandt Send a message via Yahoo to mthandt
Badly...... plastic, dry intake manifold and thin pistons make it no good. You can run it if you have a tune and know what you are doing but one little mistake and well the 4.7 isn't going to be very forgiving. There are pics of a guy that was running a 75 shot somewhere on the net where it backfired threw the intake manifold. Blew the intake up and peeled the hood open like a sardine can.
__________________
My truck is cool.
  #3
Old 03-11-2009, 12:14 PM
SLT kota's Avatar
SLT kota SLT kota is offline
Vehicle: 01 5 speed 4.7 RC Dakota SLT
iTrader Rating: (4)
Reputation: 33 SLT kota must have done something right
to put it short, not well. Most people end up blowing them up. It does do a good job at throwing the throttle up into the hood and destroying your hood as well as your motor.
__________________
-Stuart-
- 2001 Kenne Bell 4.7L 5-Speed RC
- dog # 10 first dak dog!
www.AIRRAM.com Discounted Performance Parts with FREE SHIPPING!
  #4
Old 03-11-2009, 01:53 PM
AIR_RAM's Avatar
AIR_RAM AIR_RAM is offline
www.AIRRAM.com
Vehicle: 2002 QC RAM 1500 4.7L
Reputation: 22 AIR_RAM is just getting started
There is a RIGHT WAY and a WRONG WAY... done correctly the 4.7L can handle a fair share of Nitrous. BUT you must understand that the weakest link on the 4.7L is the piston tops... so go too lean once and KABOOM!
I highly suggest you run a Wide Band Air Fuel Ratio Gauge and monitor your engines AFR at WOT... and make sure you keep it at 10.5:1 AFR to stay on the safe side. If you can do this then you will NOT have any issues.
I know of a 4.7L who has been running 100+ shots for quite a while now without any issues..> I feel he is on the edge but so far so good.
The real problem is NOT the plastic intake or even "POOLING" as some seem to think... People have come up with this theory after looking at the end result after seeing the intake in bits and pieces. The ROUTE cause of these explosions is the piston tops. Your top ring is less then 1/8 from the piston top. This means when you go LEAN (SUPER HOT) the piston top transfers much of that heat to your top ring. Your top ring expands from the heat and locks up with the cylinder... When then happens the piston tops can brake off or worse the cylinders can freeze and ANY intake valves that are OPEN with LOTS of Nitrous/fuel ignite and explode out through the intake valve... This is what causes the plastic Intake to explode into bits and pieces.
So in a nut shell, be aware of the limitations... and run nitrous accordingly. You can NOT afford to run LEAN... Make sure you run the AFR in the 10's and you should be able to run 100 shot all day long.
SPEED SAFE, AIR RAM
  #5
Old 03-12-2009, 01:06 AM
KotaKid287's Avatar
Chevy SUCKS!!!!!!!
iTrader Rating: (0)
Damn, thats more work then I wanna try on that truck right now. I guess I'm gonna have to save for gears again, and then some Caltracs to actually get the power to the ground instead of having a useless 1st gear cause of tire spinning.
__________________
You may not post new threads
You may not post replies
vB code is On
Powered by vBulletin® Version 3.6.7
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
