Tips to remove power steering pump - Dakota Durango Forum
FAQ's, Tips & Tricks Helpful technical information.
Thread Tools Rating: Thread Rating: 7 votes, 5.00 average. Display Modes
post #1 of 38 Old 03-06-2009, 06:52 PM Thread Starter
02sxtkota
No habla jibber jabber
02sxtkota's Avatar
Vehicle: 2002 dodge dakota sxt
Modifications: Bone stock except exhaust
Send a message via AIM to 02sxtkota
well gotta replace it and tomorrow i am gonna knock it out since gonna be almost 70 which is odd around here. So any tips or things i should look out for cause it looks like i gotta pull more then power steering pump off to get to it. Thank god tho cause right now parking and slow turns are a bitch and it whines like a mother fudger and i have to rev it above 2 grand for pump to work and it whines like a bitch. I dont get why core charges are so outrageous either, place i looked at 55 dollar core so ima take it off then go get new part.
02sxtkota is offline
post #2 of 38 Old 03-06-2009, 08:15 PM
Jarheadoo7
don't feed the bears
Jarheadoo7's Avatar
Vehicle: 2001 Dakota
does it whine?
Jarheadoo7 is offline
post #3 of 38 Old 03-06-2009, 10:43 PM Thread Starter
02sxtkota
02sxtkota's Avatar
Originally Posted by Jarheadoo7 View Post
does it whine?
yep, unless straight line where i dont have to touch steering wheel
post #4 of 38 Old 03-07-2009, 12:19 AM
Grapejuice1998
Registered Loser
Grapejuice1998's Avatar
Vehicle: 1998 Dakota R/T RC DA
Modifications: 408 with nitrous
Is it leaking?
Is the fluid level correct?
Have you tried "never leaks" sealer?
If you have to replace it, you will need a p/s pulley remover/installer tool. The pump, pulley and reservoir, are all separate pieces. That's why the core charge is high.
Grapejuice1998 is offline
post #5 of 38 Old 03-07-2009, 12:42 AM
realdeal7369
G.F.Y racing president
realdeal7369's Avatar
Vehicle: 2005 dodge magnum rt
Modifications: Cold air intake.
Send a message via Yahoo to realdeal7369
have you tried lucas oil stop leak and conditioner? i had an issue with a hardness in the steering. i drained out the old shit, dropped this stuff in, and let it run for a little while, while turning the wheel back and forth (get the front end off the round first though to get the stress off the steering rack and stuff)...see if it works. 8-12.oo or whatever it is, better than 55.
1997 dakota, 5.2v8, msd wires, trans cooler, K&N cai, 1.6 rr's, stinger 1700 battery, updated big 3. aeroturbine 3030 muffler, high flow cat. conv
realdeal7369 is offline
post #6 of 38 Old 03-07-2009, 03:25 AM Thread Starter
02sxtkota
02sxtkota's Avatar
Originally Posted by Grapejuice1998 View Post
Is it leaking?
tired all no leak and plenty in there, has gotten worse over time. do i need pulley tool or will a normal pulley remover work?
post #7 of 38 Old 03-07-2009, 06:09 AM
AKpirate
AKpirate's Avatar
Vehicle: 99 dodge durango/ 03 neon
have a bucket ready and lots of shop rags %$@#*!
have plenty of beer on hand too...
car domain site
5 door whore #11
AKpirate is offline
post #8 of 38 Old 03-07-2009, 06:28 AM
1LOUDRT
The Burnt Side of OJ
1LOUDRT's Avatar
Vehicle: 00/Dodge/Dakota/RT
Modifications: Car Shows, Mobile Electronics
Send a message via AIM to 1LOUDRT
if you have a harbor freight tools around the pulley remover kit is on sale right now for 9.99 or you can rent one from your local auto-parts store. Just unbolt the support bracket that mounts by by the heads/water pump and unbolt the pressure fitted line and pull of the soft line- then remove the pulley and unbolt the pump from the support bracket- Install new one in reverse- Might take a little over an hour -maybe 2 if you really don't know what your doing. Good luck!
Customized from head to toe. Truck Trends Favorite Show Truck From SEMA 2010, Truck Trend Mag Feb 2011, Feature Article CarAudio Mag and Featured in CarAudio Mag SEMA booth 2010. Truckin Magazine Full 4 page Feature issue 12, 2011. Sponsored by North Star Battery & Monzter MotorSports.
A Custom Truck is not created by how big your wallet is. It's the hands on effort you apply from your own ideas. Only then can it be called Custom-- Dynamic Installs
1LOUDRT is offline
post #9 of 38 Old 03-07-2009, 07:40 AM
modain
I drive with two feet
modain's Avatar
Vehicle: 2002 Dak QC, 2001 Durango
Modifications: Superchips 3715, no chrome, R/T rear sway bar, Monroe Reflex shocks
I'm not sure about the 3.9L engine, but the 4.7L PS pulley is plastic. If yours is plastic you might just need to buy and install a new pulley, as the current one is easily subjected to damage when removing it.
And since it is a V6 you'll have much more working room than a V8 will give you. It was worth paying to have it done on my Durango.
2002 Graphite QC SLT Plus, 4.7L, NV3500, Superchips 3715, HO Cams, 2003 Intake Manifold, Dwight's 65mm TB, 3.92 LSD, R/T rear swaybar, no chrome
2001 Patriot Blue Durango SLT, 4.7L, 545RFE, Superchips 3715, Fastman 68mm TB, Jeep GC TCM, R/T rear swaybar, 3.55 Open (for now)
1999 Forest Green Dakota RC Sport, 2.5L, NV1500, Jeep 4.0L TB, 3.92 LSD
modain is offline
post #10 of 38 Old 03-07-2009, 01:48 PM Thread Starter
02sxtkota
02sxtkota's Avatar
dont get me wrong i know what im doin i tend to over think it and make it seem worse. Damn no harbor frieght around here cause id buy it for 10 bucks
post #11 of 38 Old 03-07-2009, 04:41 PM
realdeal7369
franklin mills mall has one i think. check their website for local stores.
hey modain:
its a steel pully.
post #12 of 38 Old 03-07-2009, 06:20 PM
Grapejuice1998
Registered Loser
hey modain:
its a steel pully.
If it has a groove right at the end of the nose of the pulley, that's where the removal/installer tool goes. The groove is to remove it. The threads in the end of the pump nose are to install it.
post #13 of 38 Old 03-07-2009, 08:20 PM Thread Starter
02sxtkota
02sxtkota's Avatar
yeah has steel pulley and found a puller for 20 bucks and just waiting till tomorrow for a pump w/ resivoir to come in to finish it. Sucks tho cause the truck sitting since i took apart and no one had part cause i didnt want to pay core, oh well its good thing have others to drive.
post #14 of 38 Old 03-07-2009, 08:52 PM
UberFr0g
UberFr0g's Avatar
Vehicle: 98 dakota sport
check on your steerig rack while your in there. I went through 2 pumps in a month because of a bad rack.
good thing is i can swap a ps pump in and out in 30 mins.
UberFr0g is offline
post #15 of 38 Old 03-07-2009, 09:10 PM Thread Starter
02sxtkota
02sxtkota's Avatar
yeah wasnt to hard to get out, i took my time cause i had nothing better to do and took 45 minutes including pulling pulley and taking it off it mount.
