Squeaky Suspension - Dakota Durango Forum
post #1 of 11 Old 06-28-2005, 08:27 PM Thread Starter
Drew
Vehicle: 2000 Durango
Squeaky Suspension
Greetings All,
Do any of you know of a way to stop my 2000 D from squeaking? It seems to have that old car suspension squeak. It's rather embarrassing. Would WD-40 work or are there grease Zerks that need greasing? The squeaks seem to be coming from the back mostly and only when I go over a bump or pull into a driveway.
Thanks in advance
Drew is offline
post #2 of 11 Old 06-28-2005, 08:31 PM
QuaTscH94
July Truck of the Month
Vehicle: 02 Quad Cab & 99 RC R/T
Modifications: Bodybuilding, Truckin'
Send a message via Yahoo to QuaTscH94
Sounds like you need to grease your bushings. I was told that buying urethane bushings solves the problem for good though.
Bright Silver Metallic 02 Quad Cab 20" Chrome Wheels, Innovations Hard Tonneau, Flowmaster 3" Exhaust, CAI, Flares 2/3 Drop, Body matched Handles, Mirrors, Bumper, SS Roll Pan, Diamond Clear Headlamp Kit, Euro Chrome Tails
Solar Yellow 99 RC R/T (FOR SALE) Mopar Headers, Hard Tonneau, Flowmaster 3" Exhaust, Flares, GSM Fuel Rails, Body Matched Handles/Mirrors
QuaTscH94 is offline
post #3 of 11 Old 06-28-2005, 08:50 PM
DirtyR/T
Ninja Mode
DirtyR/T's Avatar
Vehicle: 98 Flame Red Dakota R/T
Send a message via Yahoo to DirtyR/T
yep sounds like you need new bushings. Don't use WD-40 on it. It will take what little grease is left on it off. For now you can just grease everything and that might help
Energy Suspension makes the following poly bushings for our trucks...
* Control Arm Bushings
* Rear Leaf Spring Bushings
* Front Sway Bar Bushings
* Rear Sway Bar Bushings
* Tie Rod Boots
DirtyR/T is offline
post #4 of 11 Old 06-28-2005, 09:15 PM
rtgrouchman
rtgrouchman's Avatar
Vehicle: 2001 "Amber Fire" R/T RC
Can a driveway mechanic (do it yourselfer) manage to change out the bushings? Never tried before so just wondering....have some squeaks in my ride also.
rtgrouchman is offline
post #5 of 11 Old 06-28-2005, 09:16 PM
QuaTscH94
Anything's possible man :biggthump
post #6 of 11 Old 06-28-2005, 09:57 PM
suffolk_mopar
suffolk_mopar's Avatar
Vehicle: `04 dak qc
Send a message via Yahoo to suffolk_mopar
i too have some rear end squeaks. gonna crwl under that sucker this evening
04 qc 3.7- viper fan,fast man t/b,pcm flash,borla,
p.a. body lift, runnin 265/75 a/t`s.
suffolk_mopar is offline
post #7 of 11 Old 06-28-2005, 10:35 PM
Neil
Neil's Avatar
Vehicle: 99 Durango
Can't say for sure on what build years on Daks. On Durangos, zerks were only on 98-99 and they were only in front on the Ball joints, tie rods, steering and driveshaft.
Neil is offline
post #8 of 11 Old 06-28-2005, 11:20 PM
chris4x4
secure cooler before 4Xin
Vehicle: quad cab 4x4 dakota
I too had the dreadded squeek in the rear end. I tried everything and nothing worked. EVERY spray lube you could buy, and even regular motor oil, nothing worked. An old time mechanic friend of mine told me to use brake fluid on the leaf springs and after getting sick of the noise I tried it using an old pump can to deliver the brake fluid to the desired locations, and I have not had a squeek since. No kidding! It really worked! Give it a try and let me know.
Chris
chris4x4 is offline
post #9 of 11 Old 06-29-2005, 04:31 AM Thread Starter
Drew
Chris
Now if I can just find one of those old oil pump cans!
Thanks for all the help. As for being a driveway mechanic, I wouldn't dignify myself with that title. Although I have been told I have nice tools.
Drew
Drew is offline
post #10 of 11 Old 06-29-2005, 12:27 PM
N56629
If any of you guys have worked on the rear springs you may have over-tightened the hanger and shackle bolts. This causes the metal sleeve in the bushing to rub against the hangers, in other words, metal to metal contact. Try loosening the bolts a half to one full turn. They are lock nuts and do not have to be torqued down.
99 CC 5.2 Auto 3.55 LS
WingsWest Body Kit *2/4 Western Chassis Drop
Edelbrock Pro-Flo Air Cleaner*Edelbrock Valve Covers
MSD 6A Ignition and coil
SuperChips
Modified TB & Intake Manifold
JBA Cat Back *JBA Y-Pipe *JBA Headers
Comp Hi-Tech Stainless 1.7 Roller Rockers
Minnesota Mopars
N56629 is offline
post #11 of 11 Old 06-29-2005, 02:58 PM
DirtyR/T
Ninja Mode
DirtyR/T's Avatar
mines up front. Control Arm bushings :biggthump
DirtyR/T is offline
